Question about ViewSonic VX2235WM Monitor
'No Signal' Digital
The monitor works fine at start up and I'm using it now, but everytime a fullscreen game is opened the monitor will switch off and display 'No Signal Digital' It's not the game, BioShock, since this has happened when playing other games that had worked before. I have had the monitor for a month and a half, but this has never happened.
  • Anonymous Mar 06, 2009
    Viewsonic monitor displays "No Signal Digital" on a Blue screen. We are only running Analog. How do I get rid of "NO SIGNAL DIGITAL ?"
    Thanks for any assistance.
  • alphatroop Apr 27, 2009
    im getting the same thing on my computer no signal digital can anyone help me out i know my monitor is okay cause i have a back up computer to hook up and works fine just sent my motherboard out to asus and i have it back now they said they replaced a plug on the board and im still getting the same message is there anyway i can check the graphics card its a nvidia gtx 280 amd processor and 850 watt power supply 8 gigs of ram 320 gig western digital harddrive thanks mike
I had this same problem. Tried solution "1" and voila everything's back to mint condition. Thanks for solution.
Posted on Nov 23, 2008
Solution #1 worked on my Viewsonic LED monitor today (18/01/10) so the problem is not limited to that particular monitor - but it does sound like it is a Viewsonic issue. Thanks
Posted on Jan 20, 2010
  • ViewSonic Master
  • 12,061 Answers
It sounds to me as it your monitor has a fault in the scan control circuitry, when it goes to change resolution.. ie: change frequency, the oscillator fails and the unit shuts down accordingly.. It may possibly be the Monitor Drivers, have you installed those? But even if ya haven't I don't really think this will make any difference, but one must try all things. Also make sure you have the most-up-to-date Drivers for your Video card as well B4 proceeding. If it indeed ends up being the Monitor being faulty, IE:Installing/Reinstalling Drivers etc doesn't change the behavior and because you have only had the unit for that short amount of time, & it has this "Fault". Then I feel ya should take it back for replacement/repair... under manufacturers warranty.. as this is not acceptable.
Posted on Sep 04, 2007
I spent 4-5 hours investigating this problem and the solution ended up so simple it was scary.
1. Keep the DVI cable connected to both PC and monitor
2. Turn of computer
3. Disconnect monitor power lead from monitor for 10 seconds
4. Plug it back in and off you go
Many upset Viewsonic purchasers have returned their monitors having not been able to resolve this issue!!
Posted on May 05, 2008
Why dark manor game didnot support my monitor risolution
Windows XP
  1. From your desktop, right-click and select Properties.
  2. Click the Settings tab.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and select OK.
  4. Try playing your game again.
Windows Vista
  1. From your desktop, right-click and select Personalize.
  2. Select Display Settings.
  3. Adjust your screen resolution to 1024 x 768 (or higher) and click Apply > OK.
Windows 7 and Windows 8
  1. From your desktop, right-click and select Screen resolution.
  2. Adjust your screen resolution to 1024 x 768 (or higher) and click OK.
  3. Try playing your game again.
  1. Open up the Apple menu.
  2. Select System Preferences.
  3. Click on the Displays icon.
  4. Select the Display tab to adjust your resolution to 1024 x 768 (or higher).
  5. Reopen your game.
    Try this out it seems to work for some people, if that does not work try this out:
    Switch to Windowed Mode
    If you continue to have trouble playing your game in full screen mode, switch to windowed mode. Under the main menu of the game, select Options, and un-check Full Screen mode (or vica verse if you already have windowed mode on, switch to fullscreen)
    Thanks and I would appreciate a reply if that got fixed or not.
    Good Luck!
Apr 27, 2014 |
Monitor shuts off randomly!
1. This is main-board related. You either have a Micro controller or power supply issue that needs to be address by a tech. Shut down is direct relation to a circuit component in the start up that has failed.
May 01, 2010 | ASUS Eee 4G Notebook
When computer is started no signal appear on the monitor.
If your monitor is working fine, my guess is you might forgot to turn on the monitor power switch which is located at the lower right bottom corner. try it
Sep 13, 2009 | Computers & Internet
No analog signal
Sounds like the graphics card is gone belly up. Try the monitor with another pc or just replace the graphics card.
Hope this helps
Jun 12, 2009 | ViewSonic VX2235WM Monitor
Frequncy problem/out of range
Adjust your screen settings that are usually found in the front of most pc"s and on the side of most LCD monitors
May 20, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
Analog output works fine, but no signal for digital output
is ther option on screen it self dvi mode and anlog mode .
Jan 24, 2008 | Sun - XVR-100 Graphic Card
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Jan 11, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
ViewSonic VX2235WM Monitor Logo
2,828 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
