Lexicon RV-8 V2.0 Amplifier Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lexicon RV-8 wakupe failure
Hopefully, You can help me with mij Lexicon RV-8
One morning, while the reciever was on standby, the standby-powersupply was broken down. It was replaced by a new one.
But after replacing the powersuply, the Lexicon still doesn't wakeup
Does anyone know how to start-up the Lexicon RV8 from it's coma.
greetings,
René
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on May 01, 2009
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2766047
Points
24828
Did you try this....
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
POWER MANAGEMENT ON, OFF
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
position.
2. Attempt to power on the RV-8 with the front-panel Standby
button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
  • Anonymous Feb 13, 2013
    is it alive ?
1helpful
Panasonic tc-p42x5 powersupply no power
No standby power on these sets after a power loss is usually a bad IC at location U203 on the back of the power supply board. It's a Fairchild FAN6755 8-pin surface mount IC... A cheap, easy fix if you have basic soldering skills...
RV-5 will not reboot
You have a failed circuit board, you will need to have a local repair shop test it.
1helpful
The machine constantly switches off, goes to standby or simply freezes mid use. It got so bad that eventually it just wouldn't power up. It's been back to Lexicon twice - recently they replaced the the...
I have access to the Lexicon service guys, but will need a bit more info to assist in tracking this down.
1) Have you noticed any pattern to when the unit fails. In other words, does it tend to fail more readily after being on for a while, or is it consistant in behavior regardless of time?
2) Does the volume level of the unit change the total time before failure?
3) If you uinplug the unit for 1/2 and try using it, does the behavior change?
Please update this with the answers and also, if you could post what has already been done by the service center, that would help as well.
At this point, I would be suspicious of hte 5V line and/or the microprocessor internal controls. I'll research this a bit and try to get you more details as well.
Thanks,
Dan
Why my Tagmclarenrv32 processor after about an hour the processor shuts down not the 5.1 channel amp.
I would contact Lexicon first ...These are VERY complex units
I used to work there
No Power to the lambda
Make sure the usb socket is working ,the lamda takes current from your computer.Don't use a usb hub.Make sure you are using xp service pack 2 or higher.Try another usb socket.
Amplification does not work
It sounds like a source slecton issue. Try the following and if that does not help I would start with a simple stereo setup and source and work up from there.
The RV-8 is powered on, but there is no audio.
1. Make sure volume level is audible. Volume level can be
increased with the front-panel volume knob or the remote
control VOL �� and �� buttons.
2. Make sure audio has not been muted. The message “MUTE
ON” or “FULL MUTE ON” will appear in the on-screen and
front-panel displays when audio has been muted. To deactivate
mute, press the Mute button or adjust the volume level.
3. Check the INPUT SETUP menu DIGITAL IN and ANALOG IN
parameters to ensure the appropriate audio connector is assigned
to the selected input.
4. Make sure the RV-8 is receiving an audio signal. To do this,
follow the instructions that begin on page 2-29 to open the
STATUS menu for the current input source. Hint: (Use the "STAT2" Button on the remote.)
To connect Asus Notebook to Yamaha RV-502 Av Reciever to play music
Hi, Most notebooks have a 1/8 female plugin from your audio card. (headphone Jack)
Now, you need a cord with a 1/8 male plugin on one end and two RCA Jacks on the other.
All you need to do is connect the cord to (AMP) RCA in and the 1/8 Jack to you notebook.
This will work fine. Good luck
Top Lexicon Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Lexicon Audio Player and Recorder Expert? Answer questions, earn points and help others
