Question about Gateway M280E
Problem with pen/software on Gateway M280E
When I try to use the pen in inking on microsoft word, or especially ppt. the cursor is exceptionally JUMPY when trying to use the pen on the screen. It is unusable. Those functions work fine, however when using the mouse or the touchpad. I have downloaded the most current software from gateway to try and correct the problem, but nothing seems to help. Also I have many classmates who also use the same computer, and have tried several different pens with no improvement.
    Problem Solver:
  • 36 Answers
First install the anti virus software then update the software then scan your computer after scan try again. if it cant work format your computer.
Posted on Sep 21, 2008
SOURCE:
Hard drive and cursor freeze
it sound like you might have either a virus or you don't have enough ram to run a the program you want.
Go to Cnet.com and download malware byte and check for a virus in safe mode
Oct 22, 2014 | Gateway M280E
Keep cursor moving and and drive
if the cursor is moving by it self you do have a virus. When you restart the computer bring it up in safe mode and check for a virus using maleware byte from Cnet.com
Broken swivel hinge on Gateway m280e laptop.
not sure about documentation - but for parts you might try dakotapcwarehouse.com - my company has found parts for a lot of its older gateway laptops there
Jun 03, 2010 | Gateway M280E
M280E (41891001) Tablet PC: the screen is very dark, cannot adjust brightness...
hp tablet compaq tc4200: the screen is very dark. cannot adjust in control panel, it's greyed out,
May 16, 2010 | Gateway M280E
How do I install a keyboard in a Gateway M280E Tablet? (Directions with pictures a plus, but not absolutely needed.)
Power off and remove battery. Remove 2 screws on back cover marked with a K. Open display, gently pry off long thin silver panel between display and keyboard. With fingers at top of keyboard, pull up and flip top over toward ypu, then lay flat and upside down. Disconnect flat cable and remove the keyboard. Reverse steps to replace.
Apr 21, 2010 | Gateway M280E
The stylus for my gateway m280e is unresponsive, it is able to track the cursor across the screen but it can not select anything when double tapped, or write in one note? What could be the issue?
You can change the way the cursor functions. Here is how. From the "Start Menu", select Control Panel in the (right pane), next select Hardware and Sound, select, the "Mouse". In the Mouse, "Properties" (window) change mouse functions. "I hope this "Fix it"
Jan 24, 2010 | Gateway M280E
How to set sensitivity on digital pen gateway m280e
http://support.gateway.com/s/Mobile/TabletPC/3501440/3501440faq33.shtml
try it out once..
Oct 18, 2009 | Gateway M275 Tablet PC
Hi i like to install xp profecianal on my laptop m280e i have on it xp7 tablet ther any probleme to install xp profecianal please responce
XP professional will not work on that unit. The OS will install and work properly but you will lose many of your tablet functions. You have to have the tablet pc edition for all comonents to function. You would not gain anything by going to Pro, and your Windows or Microsoft update will keep your current tablet pc edition updated properly.
Aug 18, 2009 | Gateway M280E
Pen won't click
Go to the Command Prompt form there try to format . When its format its work.
Sep 19, 2008 | Gateway M280E
Gateway M280E Logo
615 people viewed this question
Top Gateway Tablets & eReaders Experts
Ekse
Joe Negus
Joe Negus
rongg
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
