Apple iPhone Smartphone
Problem for Apple iPhone Smartphone
IPhone - Cannot connect to YouTube
By prrobsue on Sep 03, 2007
I have an iPhone with an AT&T Contract but had to activate the phone using JailBreak and iPhone interface, everything works fine except for the YouTube icon, it displays the message "Cannot connect to YouTube".
Any suggestions/workaround is greatly appreciated.
Same Problem
Apr 21, 2009
-   i can use safari to open youtube on my iphone 3g, and the pictures of the videos will show up, but when i go to watch them, it won't work.
Also the youtube button, when pressed, just says "cannot connect to youtube.
-   Guest
Apr 02, 2009
-   i have an i phone but i cant connect to edge , like i cant to you tube
-   Guest
Apr 01, 2009
-   same problem here -   jyavenard
Mar 10, 2009
-   I have iphone and every thing work okay but if I press youtube icon there is a message appear "cannot connect to youtube" please help in this matter-   get busy
Jan 05, 2009
-   i cant connect to the youtube and other software like itune stores also... i do connect to my home wireless-   PhilipChai
Best Solution
posted on Jun 04, 2008
Helpful)
SG-Auso
Rank: Apprentice
Rating: 94%, 48 votes
ok i only have an ipod touch but i figure its close to the same as the iphone. all i did was went in and set my time and date to the real time and date. some how the date was set to 2005 and i thinks hat was creating a certificate error. so far this is the quickest fix for the problem i have found.
note: my ipod is JAILBROKEN and it is currently running firmware 1.1.1
Comments:
Jun 04, 2008
- ok all i did was set my date to the real date. some how it got set to 2005 which i beleive cause certificate errors in itunes and if itunes doesnt work for some reason it negates youtube. after that my ipod worked fine. this is the quickest fix ive found so far.
note: my ipod touch is jailbroken and is running firmware 1.1.1
im sry if this double posts
Was this helpful?
Yes
No
28 people thought this was helpful
Solution #2
posted on Apr 06, 2008
Helpful)
Nickito
Rank: Apprentice
Rating: 91%, 25 votes
Hi Guys,
I have been having a very hard time with my iphone not connecting to YouTube as well. I finally got it working!!
Here is what I did:
1) restore back to 1.1.4
2) When Itunes asks for restoring or New phone, PRESS EJECT
3) Use iliberty to hack the phone but make sure that ONLY jailbreak me and installer is selected
4) After the hack is over
5) Restart Itunes and select the Iphone as being New
Hope this works for you guys!!!
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #3
posted on May 05, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
"very easy
guarnteed to work
SSH into your phone and goto (/private/var/root/Library)
delete any folder called Lockdown or Lockdown_bak and then get a back up copy of the folder Lockdown from another working iphone and copy and paste back in to (/private/var/root/Library)...then power cycle...and that's it =D"
That works very good on my iphone 1.1.4 JAILBREAK DO IT ALL with Ziphone 3.0
Thanks guy for your help ;)
Solution #4
posted on Apr 05, 2008
Helpful)
tigeronfire
Rank: Apprentice
Rating: 91%, 50 votes
I FINALLY GOT YOUTUBE WORKING...
Step 1: backup your settings and files on itunes
Step 2: restore iphone to default
Step 3: try Youtube before Jailbreak to make sure its working
Step 4: ***important*** run ziphone for JAILBREAK only!
YouTUBE remains working. when I tried to DO-IT-ALL youtube never worked afterwards.
Step 5: Sync iphone to get your settings, contacts, emails back
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #5
posted on Sep 11, 2007
Helpful)
hoi1
Rank: Apprentice
Rating: 90%, 147 votes
limitededitioniphone.com/youtube-not-working-on-your-iphone-steps-to-fix/
i follow these step and now youtube works
Was this helpful?
Yes
No
Solution #6
posted on May 04, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
very easy
guarnteed to work
Solution #7
posted on Mar 26, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my iphone cannot connect to youtube
Solution #8
posted on Mar 21, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
settings > general > reset > reset all network settings.
just had the same problem and it worked for me.
Solution #9
posted on Feb 26, 2008
Helpful)
Mikey_Tav
Rank: Apprentice
Rating: 88%, 28 votes
SSH into your phone and goto (/private/var/root/Library/Lockdown/) and remove all the files in the ("activation_records" and "pair_records") folders. Reboot and try......
Worked for me on 1.1.3 Jail broken FW.
Was this helpful?
Yes
No
Solution #10
posted on Mar 09, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I tried it on 1.1.4 jailbroken fw and it didnt work SORRY!!!! :(
Solution #11
posted on Mar 29, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
worked wonderfully! thank you so much!
Solution #12
posted on Apr 22, 2008
Helpful)
suhrob
Rank: Apprentice
Rating: 84%, 4 votes
thank you man i appreciate that, i was looking for solution for a while and yours helped me
Nickito is the best
Was this helpful?
Yes
No
Solution #13
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Did not work for 1.1.4
Solution #14
posted on May 18, 2008
Somewhat Helpful)
techman991
Rank: Guide
Rating: 86%, 12 votes
guys
there's a fix under the installer>one of the tweaks folders
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #15
posted on May 28, 2008
Somewhat Helpful)
longtilliben
Rank: Apprentice
Rating: 76%, 2 votes
hey guy this is weird but i have a similar problem.....the thing is it works with other wifi in my area but not with mine?:s
Was this helpful?
Yes
No
Solution #16
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I just downloaded MX Tube and I can finally watch again....Thanks
Solution #17
posted on Jun 02, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Just install mxtube! It works fine. I haven't had any crashes or problems with it.
Solution #18
posted on Aug 07, 2009
Somewhat Helpful)
enopog
Rank: Master
Rating: 76%, 19 votes
Hi Friends,
Problem with AppleiPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock youriPhone now you mustClick Here.
If you have any other problem with your iPhone you can try the site byClick Here. May the site can help you.
Was this helpful?
Yes
No
Solution #19
posted on Nov 19, 2008
Not Rated)
sdisk08
Rank: Apprentice
Rating: 0%, 0 votes
i have the same problem
Was this helpful?
Yes
No
Solution #20
posted on Aug 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Great work all us newbies are in debt.. thank you ty ty ty
Solution #21
posted on Jun 12, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Just download MXtube. then do a search for anything and youll see that it works.
Popular Solutions for Apple iPhone Smartphone
Questions and Unsolved Problems for Apple iPhone Smartphone
Do you recommend Apple iPhone Smartphone?
Answer
Answer
I want to sync my Palm's contact with my new iphone
Answer
Voice Mail Unavailabe: Turn iPhone off an back on again - Resolved my issue!!
Answer
my buddy sold me the iphone and 8gb i dont have a service plan. so it says no service and it says... (More)
Answer
my i phone got a bit of line crossing the screen i dont think its a crack
53 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 04, 2009
yes i cannot connect you youtube
Comment by Guest, posted on Nov 13, 2008
dsdw
Comment by mikastel, posted on Nov 06, 2008
Cannot connect to YouTube problem
Comment by Guest, posted on Sep 03, 2008
can not connect to youtube
Comment by Guest, posted on Aug 26, 2008
cqa
Comment by topron, posted on Aug 21, 2008
i used to connect fine to youtube, but since i have restored my iphone ,i get the prompt "youtube videos require an EDGE or WIFI connection"
Comment by Guest, posted on Aug 17, 2008
cannot connect to youtube... running on 1.1.4 was always able to connect to youtube but two days ago this prompt comes up - "you must first connect to itunes with an internet connection to enable youtube"
Comment by Guest, posted on Aug 10, 2008
iphone says cannot connect to you tube since i done a jail break
Comment by Guest, posted on Aug 08, 2008
I hava a phone and internet plus dsl through at and t and can't connect to you tube can you help me .. truetamason@sbcglobal.net
I have a phone and dsl through at and t but con not coonnet to you tube... can you help me?????????
Comment by nalds18, posted on Jul 19, 2008
i just cannot connect to youtube, i have an unlocked iphone
Comment by Guest, posted on Jul 12, 2008
yes
Comment by Guest, posted on Jun 30, 2008
youtube wount work on my iphone
cannot connect to youtube,the same problem
Comment by dgoose15, posted on Jun 28, 2008
youtube wont work on iphone
Comment by PokiTheKing, posted on Jun 12, 2008
Cannot connect to YouTube,
Iphone 16GB 1.1.4
Comment by Guest, posted on Jun 12, 2008
Comment by Guest, posted on Jun 11, 2008
cannot connect to you tube problem
Comment by slimrb, posted on Jun 06, 2008
got an unlocked and jailbroken iphone but cannot connect to youtube.  have tried many youtube fixes and tried jailbraking again.  Same result.
Comment by Guest, posted on Jun 06, 2008
you tube cannot connect on my iphone
Comment by boss hoghog, posted on May 30, 2008
Comment by hat038, posted on May 29, 2008
i have the same problem with my iphone "cannot connect to youtube"
Comment by Guest, posted on May 23, 2008
I have the same problem. My iphone with jailbreak cannot connect to youtube. I have tried both of the fixes on the installer but neither of them worked.
Comment by Guest, posted on May 20, 2008
yup same problem here...jailbreak the phone with iliberty+...seems to be a reoccuring problem, hopefully they get it fixed soon =)
Comment by j0keboy, posted on May 19, 2008
I used iliberty and have the same problem. please help.
Comment by Guest, posted on May 18, 2008
yeah cant connect to youtube either? wtf.... I jailbroke it with ziphone
Comment by Guest, posted on May 17, 2008
i hacked my iphone and when i go to youtube it says that it cannot connect to youtube. How do i fix it?
Comment by corky2, posted on May 14, 2008
i get the message on my iphone cannot connect to youtube. please help ?
Comment by Guest, posted on Apr 17, 2008
help me cannont connect to you tube. i just notice it days after i jailbreak my phone. i have a att iphone
Comment by Guest, posted on Apr 16, 2008
cannot connect to youtube have att activaterd firmware 1114
only utube does not work
Comment by Guest, posted on Apr 15, 2008
yep its annoying! help
Comment by Guest, posted on Apr 10, 2008
cuando hago clik en mi iphone de you tube me dice "you must first connect to itunes with an internet onnection to enable you tube pero ntes trabajaba muy bien y de repente ya no quiso entar solo me sale eso quien me puede ayudar
Comment by Guest, posted on Apr 07, 2008
Comment by Guest, posted on Apr 05, 2008
you tube on i phone not working
Comment by tigeronfire, posted on Apr 03, 2008
i have exact same problem. I am not aware of any current fixes. but i have been using MXtube instead ( occasionally crashes)
Comment by ludiqqq2, posted on Apr 01, 2008
i cannot connect to youtube
please help
Comment by Guest, posted on Mar 30, 2008
yes
Comment by Guest, posted on Mar 26, 2008
Comment by Guest, posted on Mar 22, 2008
reset settings
Comment by joseph1961, posted on Mar 16, 2008
i having the same problem....after jailbreak and unlocked the iphone with firmware 1.1.4
Comment by jbird540_0, posted on Mar 07, 2008
I just jailbroke my 1.1.4 iphone using Ziphone 2.5. Everything works except it says "Cannot connect to Youtube."
Comment by com5984, posted on Mar 03, 2008
I have the same problem but the error message is "you must first connect to itunes with an internet connection to enable you tube" I can connect to itunes over wifi on my iphone but can't work out how to enable you tube
Cheers
Rob
Comment by Guest, posted on Feb 22, 2008
yeah same problem, Wht's the solution?
Comment by vallejxl, posted on Jan 02, 2008
same thing but I jailbroke it before and it worked fine this just started happening now, I´m using Movistar
Comment by Guest, posted on Dec 26, 2007
i have YouTube; however, when I try to use it I can't because it shows Cannot connect to YouTube
Comment by Frankiefig, posted on Nov 24, 2007
same thing but i jailbroke it before and it worked fine this just started happening now. i also use att
Comment by Guest, posted on Nov 23, 2007
me too i have the same problem,
Comment by sagarkapoor, posted on Nov 06, 2007
i have the same problem. when i try to search or connect to youtube it says
cannot connect to youtube.... i have not taken any steps to fix it
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iPhone Smartphone:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
