Question about Frigidaire FWS445RF
Washer will not drain
Our washer will go through the first 2 cycles, but it will not drain and spin. We check the pump motor and it is working good. Wondering what else could be the problem.
    President:
  • 1,294 Answers
Your outlet filter is probably clogged; this requires periodic cleaning according to usage. Clean this out and refit. Ref manual. Be prepared for water to come out of the front so keep some towels or pan handy.
Posted on Sep 04, 2007
SOURCE:
Krazytech
  • 725 Answers
SOURCE: washer go though all cycles but no spin
not a mechanical timer in this one..
Posted on Aug 30, 2007
  • 365 Answers
SOURCE: water not draining during rinse cycle
check the drive belt for the pump under the machine
Posted on May 09, 2009
erpaalai
  • 999 Answers
SOURCE: I still have water in my washer after drain and
There is a cleanout on the pump. Remove the front lower panel for access.
Eric
Posted on Jun 24, 2009
miket756
  • 2702 Answers
SOURCE: Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
Posted on Jun 08, 2010
Jahn27
  • 1554 Answers
SOURCE: Whirlpool LSR7133KQ0 top load washer.
This is definitely a lid switch problem. The drain pump doesn't work because the motor doesn't work in the spin mode. The drain pump is attached to rear spline of the drive motor. During the agitate cycle, the motor turns in such a way that the pump turns in reverse and instead of pumping out water, it pumps water in. During the spin cycle, the motor turns in the opposite direction which make the drain pump pump the water out. This function is activated through the lid switch.
Make sure the lid switch actuator is intact and installed properly. Raise the lid and activate the lid switch manually by pushing it down with an insulated or insulator material. Replace the lid switch (part number 3949247) if the machine still does not spin.
Unplug the machine or disconnect power then release the console from the top of the cabinet by removing the screws securing the rear of the console. Pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine. Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Aug 07, 2011
My washer won't spin on spin cycle
Hi rapwizz,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Whirlpool Washing Machines
Water not draining from washer. cannot open door. isnt there just a spin cycle i could go to instead of the entire wash cycle? i have already put it through 2 more cycles hoping the spin would drain...
Hi lauraeuschwa,
Kind Regards :-)
Jul 18, 2011 | Kenmore HE2 Plus Front Load Washer
Spin cycle appears to be broken. washer just hums
Humming can indicate a stalled motor...If a coin is jammed in the pump impeller it will often do what you describe...Check via pump filter access door...Good luck....Nomess
May 08, 2010 | LG WM1814CW Front Load Washer
The washer didn't spin or drain out. So, I turned
The washer has a separate pump to drain. You manually drain out that means the pump is good. The agitation and spin rotations are from one motor and this motor has 2 directions with 2 mechanisms to assist the actions when the motor connections is controlled by the set table. When the parts contributed to the mechanism fails you can have only one function or neither of them. To examine the mechanical failure, need to access to the inside to inspect the clutch, the brake, the helix... This needs a service man or if you can do it if you are handy. To confirm the problem, here are things to check without taking the washer apart.
1- If you have agitation, but no spinning, then your motor is good, just the spinning mechanism is failing. Need to replace a small part of the mechanism after inspection. In this case, you can't even run a manual spinning. 2- If you don't have agitation then you may have the motor problem. 3- If you hear motor sound but no turning, then need to inspect the belt or direct drive mechanism. The spinning mechanism part is not expensive but the labor is not since there is a lot of work to get to this point. Just to give you the idea to avoid the recognize a rip-off. There is a plastic pulley when engaged with a reversed rotation will push the brake open so a spinning action can function. When this plastic is worn out, it can't engage therefore no spinning.
Jan 02, 2010 | Washing Machines
Maytag PAV2000AWW will not drain or spin in 2 of the 3 wash cycle
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 27, 2009 | Maytag Washing Machines
GE washer will not empty when put into spin cycle
If the washer spins but does not drain the water out, then your pump is not working. If it is a newer model, then it has a separate motor to run the pump than it has for the spin cycle. If this is indeed the case, then there are a few things that could cause this:
1) the pump itself is bad
2) the pump motor is bad
3) the timer isn't sending power to the pump motor.
depending on your level of mechanical competency, you could try to check at the pump to see/hear/feel if the pump seems like it is running during the drain/spin cycle. If it does not give any indication of movement, check the power going to the pump. There should be a connector the pump plugs into, check there for 120V A/C with the proper meter/test light. if the power is present and the motor isn't running, you've found your problem.
If the motor does sound like it's running, the pump itself is likely bad or you have a blockage in one of the hoses to or from the pump.
If no power to the pump motor, verify that you have the timer in the drain/spin cycle. If you do, then it is likely your timer is bad.
Hope this helps
Nov 01, 2009 | Washing Machines
My washer will not spin in any cycles
i would still want to removehte motor and check for a craked motor coupling, if its cracked the tub willl not spin( or agitate) but will drain.
Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Washer does not drain when in the spin cycle
lean washer back remove the 2 clips holdong pump to motor remove the 2 clamps on hoses remove pump and ckd for blockage
Jun 04, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
