Question about Brother XL-3510 Mechanical Sewing Machine
Bobbin shuttle problem not solved
Earlier, I posted a problem about the shuttle driver that holds the bobbin in my machine. I took it apart to replace the bobbin and cannot, for some reason, get it back together. And although someone did respond and give me a picture to look at and a website to go to, this did not solve the problem, as my machine doesn't have the quick set bobbin. There are 3 pieces, the little metal bobbin holder, the metal piece that it attaches to and then the cover that goes over that and has 2 arms that snap onto it to hold it all in the machine. I cant remember where to put the thread from the bobbin through the holder and also get it in the proper place. Can anyone help me please?? Thank you so much. Shelby
  • 1 more comment
  • mgonyon Sep 04, 2007
    Hi...
    I do apologize, I had my son read me the model number on the sewing machine and he read me the numbers wrong. My machine is actually a Brother XL-5310. I did find the manual for it, however, on the same site you directed me to, so thank you so much for your help. It turned out to be a mechanical problem so I took the machine back and purchased a Singer. :) Thanks again!!
    Shelby
  • Anonymous Mar 18, 2014
    cant remember hold the black bobing hold sits in the machine need help plz
  • Anonymous Apr 01, 2014
    there are 4 parts to it, the bobbin, the holder, the half disc and the plate that holds them all in. Can't get the last two pieces in and latched with the black-stops.
    President:
  • 1,114 Answers
Did you download the manual from the link I provided? Both the normal & quick set bobbins are covered on pages 27 - 30 Here is the direct link to the manual: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000242/xl3500_t_3510ug01enes.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 03, 2007
These parts came off on the LS-2220 Brother sewing machine. How do I fix it.
Good that you included the photo...
The 2 pieces look like the hook and the retainer ring that hold the bobbin.
The piece to the left is the hook ... one to right the retainer ring. The bobbin fits into the hook.
There is a diagram below that should help.
The two black 3/4" long levers need to be twisted outward...then put the hook in ... followed by the retainer ring .... and then twist the two levers back.
Generally the two parts will only fit in a certian way to be able to successfully twist the levers back ... could be some trail and error
capture-ndcrf45py13iteczuh5ab3ob-1-0.png I tried posting another diagram but fixya would not upload it ... I will post this answer and then try to add the second diagram
Feb 09, 2018 | Brother Sewing Machines
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
Upper thread on embroidery machine jamming machine, and ending up with a bird's nest in the bobbin area.
Upper threading is wrong. Thread could be catching on the end of the spool. What machine are you using?
Apr 28, 2015 | Sewing Machines
How to put string into the shuttle
I take it you have a shuttle with a bobbin inside. Remove bobbin and attach it to the bobbin winder by the balance wheel, wind bobbin and while holding shuttle point downwards drop the into the shuttle, pull thread down to the bottom of side slot and then straight up under tension spring, load shuttle back into machine pointed towards you tension screw up
Feb 12, 2014 | Sewing Machines
Upper thread getting caught on bobbin spool
Has your machine worked before? Check that it is the correct bobbin and bobbin case. Although,if it is the spindle that is sticking out through the bobbin case, that is the shuttle. Perhaps the shuttle is not seated correctly.
Otherwise, it would probably be good to take it for service.
Jan 06, 2018 | Brother Sewing Machines
Singer 8280 (prelude) I had 2 threads coming out from my bobbin area, so I decided to open it up and take a look. I accidentally took out the whole bobbin shuttle. The manual doesn't tell me how to...
Ok, hang on! This can get tricky! Remove the bobbin. Remove the presser foot and the needle. Remove the throat plate. This gives you plenty of room to monkey with your bobbin case. NOW, lay the bobbin case in its correct area and gently rotate it until it falls into place. It may take several tries. Once you're satisfied that it's secure, snap the holding clips into place and it should all fit nicely. THEN place your bobbin in the case correctly...check the diagram in the manual. Depending on the machine, some bobbins have the threads coming off counterclockwise and others have them coming off clockwise, but your manual should show. Sometimes, there's even a diagram on the throat plate or the bobbin case as well.
Good luck. Hope this works. If this solves your problem, please come back and rate my answer!
Jun 07, 2011 | Singer 8280 Mechanical Sewing Machine
Consew226 needle not picking up bobbin thread
I would just send it to a mechanic.
Aug 03, 2010 | Consew 226R-1
Problem inserting bobbin
Inserting bobbin into the bobbin case or problem inserting bobbin case into the shuttle?
Make sure the thread will feed from the bobbin clockwise and through the guide on the bobbin case.
Lift the lever on the bobbin case to hold the bobbin in place as you inset the bobbin case into the shuttle.
If the bobbin case for this machine as a "finger", this has to align with the opening in the shuttle.
If you cannot readily see this - move the bobbin case a bit to the left and right until it clicks into place.
Feb 20, 2010 | Necchi 6018 Mechanical Sewing Machine
Shuttle
The bobbin should be placed in the shuttle, with the needle at the top end travel. You can watch the shuttle move as the hand wheel is turned.
Jul 09, 2008 | Sewing Machines
Shuttle alignment and assembly
The shuttle/race/bobbin system shouldn't really be taken apart by the average user. Unfortunately, your chances of ever getting it back together properly so the machine will sew (this is the timing of the machine) are very slim. You'll need to take it to a sewing machine technician. I would recommend an authorized Pfaff tech as they'll be sure to have the proper tools to do this correctly - won't be inexpensive but will be worth it. Most "neighborhood sewing machine repair folks" don't have experience on computer machines. Resetting timing on a computer machine isn't the same as the old mechanicals and requires some expertise.
May 02, 2008 | PfaFF Creative 7570
Brother XL-3510 Mechanical Sewing Machine Logo
207 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
