Question about Toastmaster 1142 Bread Maker
User manual lost user manual and need to know how to tell when to take dough out to bake in oven
Http://www.useandcaremanuals.com/pdf/B200566.pdf has original manual
Posted on Sep 04, 2007
Help. my breadmaker wont finish cycles display just says "-" anyone know why?
You have it on the setting that just mixes it and proves the dough, knocks the dough back (that is a bread making term, knocks the air out of it), and then leaves you to remove the dough, shape it, re-prove and then bake in a conventional oven. check your manual.
Andrew - master bread maker :)
Sep 03, 2015 | Kitchen Appliances - Others
Mixing OK but not heating/baking
That's not a good sign. This will keep your bread from rising properly and baking, obviously.
If you are still under warranty, contact your manufacturer, otherwise, you can still use the machine to mix but you will need to use your oven to finish your bread.
If your bread is not rising in the machine:
  • Remove mxing chamber from machine
  • If the chamber is not removable, UN-PLUG THE BREAD MACHINE so the blades DO NOT TURN.
  • Be careful of the mixing blade in the chamber
  • Remove dough gently with slightly oiled hands into a lightly oiled bowl with room for about 2x the volume of the dough
  • Cover with plastic wrap to prevent the dough from drying
  • Place the bowl of dough in an unheated oven and leave the oven OFF
  • Place an empty lasagna pan in the cold oven on a shelf below the dough or on the floor of the oven if there are no exposed elements
  • Boil some water and pour it carefully into the lasagna pan
  • Close the oven door - You have just made a proofing box. The steam and heat from the boiled water is sufficient to make a great proofing cabinet out of your oven hot box
  • Allow the dough to rise to about twice the original volume
  • remove the dough from the oven and remove the pan of water
  • continue with the baking instructions below
If your bread is rising in the machine or you have finished the above instructions:
  • Remove dough gently with slightly oiled hands into bread pans. Breadmakers are different sizes so you may need to use one or two pans. Or make an artisan style loaf on a cookie sheet lined with parchment.
  • Be careful not to compress your risen dough as this will make the loaves dense
  • You may also choose to make buns by separating the dough into smaller balls and placing on parchment lined cookie sheets
  • You can allow the dough to rise again for a short time in the proofing box above but I would just leave them on the counter under clean towels to prevent drying for say another 20 minutes. Over-rising bread should also be prevented. The result will be 'deflated' looking bread.
  • Preheat your oven to 375F and bake the bread until it is golden and makes a hollow sound when thumped on the top or the bottom crust
Personally, I love that a machine will mix and knead my dough for me while i go do something else but I don't like the appearance of a machine baked bread. I like the artisan hand-made look. I recommend you keep the breadmaker until you find one you like that is drastically reduced in price and just use the artisan proofing & baking options above.
If you have a Pizza Stone, you can also try that for baking an artisan bread. Use the breadmaker as the workhorse, use your oven as an artist.
Good Luck and may the Yeast be Lively!
Apr 02, 2015 | Kitchen Appliances - Others
How do i get breadmaker just to bake?
According to the manual, I don't think there is a bake only mode. There is a "dough mode" that reads "Use this setting for yeast recipes that only require mixing, kneading and will be shaped by hand. After the end of the first rise, remove the dough, shape the dough and bake it in a conventional oven."
I wasn't able to find a 1010 manual, but did find one for a 1021 (I believe that they are similar). You can download a copy here:
http://kitchen.manualsonline.com/mdownloads/d150413a-28fb-4636-9a77-0d39a015dddb.pdf
Apr 24, 2014 | Pillsbury 1010 Bread & Dough Maker...
Lost manual for Frigidaire gallery gas oven. need to know how to use convection baking
What model Frigidaire oven do you have? Most Frigidaire manuals are available from the manufacturer's site: http://b2b.frigidaire.com/support/manuals.asp or http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/ . Note: these manuals are in the PDF format; you will need Adobe Reader or a similar program to read them.
For example the User's manual for the FGGF3054MW range (with convection oven) is available at http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316901218en.pdf .
I hope this helps.
Apr 13, 2013 | Frigidaire Gallery 30" Self-Cleaning...
At what time can I remove the paddle before my B&D breadmaker bakes the loaf?
The Use and Care Manual for your Black & Decker B2250 All-In-One Automatic Breadmaker can be dowloaded in PDF from the following link:
http://useandcaremanuals.com/pdf/B220,B2250984.pdf
Follow a recipe similar to that for Dinner Rolls on Page 19 where you would use the Dough Setting to allow the dough to be removed for shaping and baking in your regular oven.
May 18, 2012 | Black & Decker Bread Machine
Lost my manual, need to know how i could stop the machine after knead/rise mode without the machine automatically switching to bake mode.
I may have a copy of your manual but I would need to know the Model #
The answer to your question is that you want to select the "Dough" program. It only does a knead and rise cycles, no bake cycle at the end.
Feb 18, 2011 | Regal Ware Kitchen Appliances - Others
Using the same recipe I've used many times, the machine stopped after mixing and before rising, and all lights went off, and did not come back on after a half hour. I am going to start over. However, I am...
If the bread maker still works, means that you had a temporary power outage. You can naturally bake it in the oven, but you will have to allow time for the yeast to activate and rise the dough to approximately double size than the starting dough. You can use a cooking pot full of warm (120-135f) and have the dough seating over it (in the pan that you will bake it in).Cover the whole thing (water and dough)with terry cloth towel for minimum of 45 minutes and bake it in a pre-heated oven (425f). Avoid any drafts durring the rising of the dough.
Jan 16, 2011 | Panasonic Kitchen Appliances - Others
Need a manual for west Bend Bakers choice plus 1
http://www.focuselectrics.com/catalog.cfm?dest=dir&linkid=54&linkon=category
http://www.focuselectrics.com/supportdata/L4979revised.pdf
Here are two links. The first is to West Bend where you can enter your model #. the second is a West Bend general users manual. Hope this helps. Steve
Dec 19, 2008 | West Bend 41089 Bread & Dough Maker
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Toastmaster 1142 Bread Maker Logo
225 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Mohamed Ismail
Mohamed Ismail
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
