Question about Fuji FinePix S5200 / S5600 Digital Camera
CAMERA WILL NOT TURN ON
MY FUJI S5600 WILL NOT TURN ON IN CAMERA MODE, WELL THE SCREEN IS BLANK AND THE SHUTTER WILL NOT RELEASE. IT WORKS FINE IN PREVIEW MODE WHICH IS THE FIRST POSITION ON THE MAIN (ON SWITCH) THEN CAMERA MODE NOTHING CAN ANYONE HELP PLEASE
Try new good quality batteries.
i experienced this issue last night. Even after replacing the batteries i had the same problem though the batteries were from a very cheap pack & i'd had them a while. The camera worked fine once i'd recharged my normal batteries. I'm no expert but I expect switching the camera on must use much more power then review mode causing the camera to switch off before it has time to tell you your batteries are low.
Hope this solves your problem!
Posted on Nov 11, 2007
Fuji finepix S5600 won't take pictures
A possible solution could be found in the menu of the camera. Scroll through the menu and look for any dropdown menu that deals with mode and see if the correct mode is selected.
Apr 15, 2014 | Fuji FinePix S5200 / S5600 Digital Camera
How do you use timer for a group photo
Press cursor-down (marked with a one-handed clock) to cycle through the different self-timer settings. Start the self-timer by pressing the shutter release button.
May 29, 2011 | Fuji FinePix S5200 / S5600 Digital Camera
Is there a timer on my camera
Yes. Press cursor-down (marked with a one-handed clock) to cycle through the different self-timer settings. Start the self-timer by pressing the shutter release button.
Apr 20, 2011 | Fuji FinePix S5200 / S5600 Digital Camera
My camera will also show pics that I have already taken so I know the screen is still good but won't go into camera mode. I changed the batteries, even the card and still have the problem. I have been...
If it won't go into camera mode then maybe the micro switch underneath the swtich is damaged. It's on a small pcb with 2 micro switches for either of the 2 functions. play back and camera
Jan 18, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
Fuji S5200. Shutter stuck in the open position.
Hello
Thank you for using FixYa for your problem
Do you live in a humided area, this can cause the shutter to stick or has the unit been sitting for a while?
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 02, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Shutter does not work.
It's not a shutter, but aperture unit is jammed.
Try these: Move lens all the way out and while pressing release button, gently tap on the tip of the lens using something soft/havy like small rubber hammer or piece of rubber.
Apr 16, 2009 | Fuji FinePix E500 Digital Camera
Can't get it to picture mode
This camera's playback function works through the lever around the shutter release button. Change it to picture taking mode (the red camera icon).
Feb 14, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
I want to have the camera take a pic of my family on its own
Yes. You can even choose between 2 seconds and 10 seconds. Put the people in the shot. Focus the camera on them by holding the shutter button down halfway, and without releasing the shutter button, press the button all the way down to start the self-timer. (That's what the manual says. I go into the menu on the camera and set it up that way.) To do it from the menu: when the camera is on, hit the menu/ok key. The self-timer mode will pop up. Hit the right arrow. Here you can choose between the 2 and 10 second timer options. Select one. The timer won't start until you have pressed the shutter button halfway to focus and press the shutter button all the way down as stated earlier.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Camera/screen works in playback but not in camera mode
This always happened to me when my batteries were low. Disappeared as soon as I changed them.
Oct 27, 2007 | Fuji FinePix E550 Digital Camera
Screen works in playback mode but turns off in camera mode as if batteries are going dead.
For some reason, Fuji does not emphasize that if your batteries get low, this is what happens. You just need recharged batteries or new batteries. Be careful with rechargables--before recharging them when this happens, you first have to drain them using the discharge mode of your camera. Then they will take a complete charge. (Good for some 300 charges or so, I believe.) But if you don't discharge them first, they will take less and less of a charge, and last shorter and shorter. If you use regular batteries, they might not last for 50 pics before running out of juice.
Fuji FinePix S5200 / S5600 Digital Camera Logo
215 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
