Question about Brother MFC 240C All-In-One InkJet Printer
Get troubleshooting message
Paper jammed. removed the paper. now getting trouble shooting routine maintenance won't print. what happened ?
  • 832 Answers
The encoderstrip which gives the head the position is out of place. You have to open the printer (cable, cover, screws..) and to put the encoder strip into the right place on top of the printhead. The encoderstrip is the foil which runs paralell to the drivebelt of printhead.
Posted on Sep 20, 2007
We do have a sheet that is jammed, we are unable to pull it out, we did try from the back, underneath and also opened the front, but unable to pull out the toner and the drum. Please help as soon as...
Hi goldenhor978,
I see that you are having issues with you Brother DCP-7030 All-In-One Printer.
You mentioned that you have a jam in it but could not pull it out and that you have tried all possible options to remove the Jam.
Check this link it has all the information that can help you with your concern, it also has visual pictures to show how and what other options you can do to remove the Jam.
Manual Trouble shooting Guide.
In the manual Go to section IV Appendixes,B troubleshooting and Routine, Error and Maintenance Messages, Paper Jam.
Follow the steps where you can locate the paper Jam troubleshooting for further details on your Query.
I hope that this helps.
Thank you for choosing Fixya,
Jun 21, 2011 | Brother DCP-7030 Digital All-in-One Laser...
Read the users guide and do what they say in the Troubleshooting and Routine Maintence Chapter for the "Print Unable 50" error message.
Mar 29, 2011 | Office Equipment & Supplies
MFC-240 I had a paper jam the other day and I
May be you should have the printer checked by a qualified technician.
I guess that when you aunt removed the paper, she did it by applying excessive force causing damage to the printer mechanic.
Mar 15, 2010 | Brother Multi-Function Center MFC-240C...
I am having a problem as well. I can't use the Fax either. Very difficult to see th jammed paper. Followed all instructions, but unable to clear the jam.
Feb 18, 2009 | Brother Multi-Function Center MFC-3360c...
good day! Unable to print 50 means'' the machine does not work due to paper jam or some sensor...mostly unable to print 50 is sensor problem. to clear the problem clean the sensor, and then the mechanical...t
Dec 07, 2017 | Brother MFC 210C All-In-One InkJet Printer
DCP 115C does not print
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely
the manual states for this problem
"The machine has a mechanical problem.
A foreign obstacle such as a clip or ripped
paper is in the machine."
Aug 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Not printing
my printer doesnt work, what do i need to do so that i can use my printer again,pls kindly give me the information, it always said that go to the maintenance and routine maintenance chapter. i have no any idea on that device, pls!!! thanks!!!
Jul 03, 2008 | Brother DCP 130C All-In-One InkJet Printer
Error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
122 people viewed this question
James Cagle
James Cagle
Jim Keysor
