Question about JVC RX-DV31SL Receiver
Optical audio not working
I am trying to get optical audio in from my Samsung 5087 DLP TV. I can see red light coming in from the cable from the tv, when I plug it into the JVC the display recognizes that it is hooked up but no sound comes out. I have it set to Digital input and TV for digital in. Any suggestions? Are the two devices compatible? Thanks!
  • Stevehose Sep 04, 2007
    After further testing, I believe the problem is that if you have HDMI in to TV from cable box, then optival out is blocked for some reason. When I switched to the built in TV tuner the optical worked fine on the JVC.
I have this problem but i dont have a cable box, if i use rca's i get sound but optical cable nothing
Posted on Oct 08, 2007
Connecting Samsung TV to Sherwood Newcastle R 865 Receiver using optic cable.
The problem might lie with the TV itself. The optical input might be switched off. You can check if the signal is coming out of the TV. With the optical lead plugged into the TV and the TV on. But not plugged into the Amp. You should see a red light come out of the unconnected end. If you don't see that the socket is switched off at the TV end. It might come under sound in the menu, or options, or digital audio output. Or a combination leading to the other!
If you see an option for Dolby Digital, set that to on as well. Some HD TV channels use Dolby, but others don't. It will only come on with certain films and TV shows though, it should switch your receiver to the Dolby setting, just like DVD and Blue Ray discs do.
Apr 24, 2016 | Sherwood Audio Players & Recorders
I'm trying to hook up a sound bar to my 32 inch Samsung smart tv using a standard audio optical cable and I can't get the cable to stay in the holes what am I doing wrong
If your getting same result on both ends of cable then your not inserting the cable correctly. It only goes in one way and make sure when you push it in be firm and it will click into place or feel like it does. Give it a slight pull if it doesn't come out of back of tv then your good. Also after you plug into back of tv look for a red light on the other end of cable. If you see a red light on other end while tv is on then you got it connected properly into back of tv.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Mar 10, 2016 | Samsung 5500 Series UN32F5500AF 32" LED...
How to connect my bose solo to my 2009 samsung tv
sounds like you have it set correctly..do you have any other sources than external,(such as audio out) ?If so that should solve your problem...does the system have any other connection outs, such as red white audio cables (LR audio )? You can use them as external when the optical is unplugged...if you get sound you either have a bad optical cord or the output for it is defective..good luck GOD BLESS
Oct 12, 2017 | Samsung LN46D630 46 inch LCD 630 Series TV
I see red dots on screen of dlp samsung tv. Not sure why. Could be a bad lamp? When I watch tv thru regular tv cable between cable box and tv , the tv is loosing signal.Thru s video signal is ok.
optic block failure is the dotty appearance use your model number to shop around for a new one and the coaxial input's are easy to break loose so use s-video if at all possibly ok
Dec 31, 2010 | Samsung DLP HL-P5663W 56" TV
Connecting HT/Cable box to TV?
Get a fiber optic (Toslink Optical) cable to plug into the TV's optical OUT between the red/white RCA audio and the spot where you plug in your cable TV, to the Optical IN on your HT-DS610. This way all audio coming in to your TV from any source goes directly to your hi-fi in all it's splendor.
Have fun!
Aug 28, 2009 | Samsung HP-S5053 Television
Need to connect some samsung audio/video components
I'm guessing that you would like all your components to play audio through the HTZ320. In order to get audio from all these components you will need a digital optical cable from the tv optical out to the HTZ320 optical input. And some composit audio cables (red and white) from tv audio out to the HTZ320 aux input. The video and audio from the dish box, bluray, and the vcr are all going to have to go through the tv first and then to the HTZ320. Use HDMI cables to connect the dish box and the bluray to the tv inputs and composit cables (red white and yellow) from the vcr output to the tv input. If you can give the exact model of the tv I can help you sort things out further. I hope this helps you.
Aug 27, 2009 | Samsung Audio Players & Recorders
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
PS3 PROBLEM
bear with me i'm working on a solution for you just be patient we will get it figured out
Sep 06, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
JVC RX-DV31SL Receiver Logo
259 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
