Question about Sony PlayStation 2 (PS2) Console
B & W only
Screen comes in only black and white. i switched TV's same problem - any suggestions?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
1) Set the colour system of your TV set to Auto System. 2) Try NTSC-PAL convertor between PS2 and TV. If both of the above doesn't work then it is a technical fault inside motherboard and it will be fixed by a technician only.
Posted on Sep 07, 2007
Screen keeps going black then grey and white lines start to come across the screen.
This is not the fault with remote control. It is with your TV itself. Contact any service technician.
Gopakumar Gopalan Google
Mar 24, 2014 | Televison & Video
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
Color went to black and white
You have it hooked up to Analog TV with your RCA jacks. I had the same problem.
Jul 23, 2010 | RCA F19431 19" TV
Black/white/rainbow screen
Sounds like power board issues, if your able test the voltages coming out of it and see if they are correct
Nov 23, 2017 | Insignia 19 in. Widescreen Flat-Panel LCD...
No picture - then picture is black and white w/ a split screen?????
it happened to me once i ended up gettin a new screen. not sure about you but i had the same symptons
Oct 27, 2008 | Toshiba 65HM167 65" Projection Television
No color
CHECK THE SYSTEM IC
Sep 06, 2008 | Akai CTS2550 25" TV
Games are only coming through in black and white
when you switch it on hold down the power button for 4 seconds and it runs the display set up
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
Sony PlayStation 2 (PS2) Console Logo
112 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
