posted by rhomaios on Sep 03, 2007
got rid of vista on my acer aspire 3680. now i have xp again...yeah! I have three devices that will not work. "Mass Storage controller" "Video Controller" and "Video Controller (VGA compatible)" I downloaded the apropriate drivers from the acer site but every time I install them they crash my cp.
2 Other Users Have The Same Problem
Comment by Guest, posted on Jul 18, 2008
acer aspire 3680 laptop
Comment by reXXar, posted on Mar 14, 2008
i've changed my home basic vista to vista ultimate which has cause my wireless network adapter, mass storage controller & unknown device to stop working. i only can download the wifi driver automatically through internet but hopeless with the other two. untill know i cannot find the installer. help me...
Best Solution
posted on Sep 03, 2007
it may be that there is a problem with the bios, as Vista enabled laptops have a later bios version, but i assume that you have exclamation marks where you mention these devices, if not then you have windows generic drivers running instead which will need to be uninstalled first especially the raphics driver as that would cause the main crashes.
if you have no exclamation marks against these devices right click on each and select uninstall.
Try again to install or run the drivers then restart the notebook and see which drivers the system tries to install, if you get the choice install them manually and point windows to install the drivers from where you have them saved if you are unable to run them.
if you do succeed my advice is to install Vista on a seperate partition as i did so as to enable a dual boot and have both systems available when i need them
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Acer Aspire 3680 Laptop/Notebook 80GB
Email this problem
Email this problem
Can you Help with these PC Laptops problems?
Acer Aspire 3680 Laptop/Notebook 80GB 14-WXGA...
acer 3680 ac pin broken
Hi there, I have an acer 3680... Answer This...
je veux dowlaod a rapair reset...
chez expert mon loptop acer... Answer This...
My acer Aspire 3680 notebook...
Formerly the sound works. But... Answer This...
how do I reset the memory...
how do I reset the memory... Answer This...
Acer incompatability with...
Tried to download and install... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
