Question about Alpine CDA-9883 CD Player
Wont turn on
I have everything connected right and the stereo still wont work could it be a fuse?
  • captin Homer Mar 11, 2008
    My brand new Alpine CDA-9883 will shut off at randem times and may not come back on for weeks and sometimes come on and off many times in a row. Help!!!!
  • 752 Answers
Could be. you should test the voltage on the yellow wire and red wire. Both should be 12 volts with the car on.
Posted on Sep 15, 2007
SOURCE:
Replaced stereo in 2004 Ford F-150: used a ford wiring harness with all wires connected correctly, but no power to stereo??
Check for a inline fuse, if no fuse is found, fit a power wire from the ignition switch to the power connection on the stereo via a inline fuse.
Oct 20, 2017 | Ford Cars & Trucks
2001 Stratus Coupe. new battery and starter. engine wont crank when i turn the key. also no dash lights
You need to clean all the batt. and starter solenoid connections.
make sure they are tight
make sure to clean batt neg wire at body connection
check your fuse link to starter from battery,
a 6 inch section of thinner wire designed to burn out to protect starter. this is why you can jump starter you bypass the blown fuse link.
mike
Mar 25, 2016 | Eastern 2001 Dodge Stratus - Coupe, 2.4L...
Impala radio not working
did you check the fuse
Nov 28, 2013 | Cars & Trucks
Audi a4 b5 1996 1.8t aftermarket stereo wont work??
please test the fuse for open or dirty or corrosion or bad contact.
2) tight the wires connector very well.
3) see if the connection are propely connected and not missing
see the diagram attached.
God bless you
Jul 14, 2012 | 1996 Audi A4
BCM Replace/install aftermarket stereo trouble
you have burned out your large box fuses under the hood and, possibly a fuseable link or, two check them
next time connect the hot/red wire only to an inline properly rated fuse connected to the battery positive lug
the library or, a dealer will have your car's schematic
And use wirenuts to connect wires not crimp connectors
May 28, 2009 | 2006 Chevrolet Cobalt
Put an aftermarket stereo in my 2006 nissan altima stereo turns on and works but it blows my 10 amp taillamp fuse. makes my ac knob lights turn off my gearshifter indicater turns off as well foglamps and...
The problem is bad wire connections, check the connections you made, if you don't understand the diagrams go to an expert.
You can cause major problems if you keep trying and doing it wrongly.
If you know what you're doing, if everything is ok and the problem persists try the same stereo in another car to check if the problem is that.
May 02, 2009 | Kenwood KDC-MP205 CD Player
Carolla stereo wont turn on..
Have you checked the fuse? Looks like ther is no power coming to the radio so best bet it's the fuse.
Cheers.
Nov 09, 2008 | 2004 Toyota Corolla
Car stereo help
There are some tests you can perform for checking the stereo. Yes, you are right, there is a yellow and red wire. Yellow constant power, red is switched throught the ignition. During the installation, you may have blown a fuse. A bigger fuse is not needed, stick with the same size if you find a bad fuse. Hook the red and yellow wire together for TESTING PURPOSES to one or the other of the hot wires in the vehicle. This will also test to see if you have a bad fuse. If the stereo powers up in one or the other power connections in the car and works, you have a blown fuse. I have seen some fuses be located under the hood of the car near the car battery. Hope this helps, Bob
Oct 29, 2008 | Car Audio & Video
My stereo wont turn on
try replacing the fuse for the radio. it will look clould/blackish and the little metal piece running in it wont be connected. It should be underneath the steering wheel and should be labled. if you have trouble finding it, consult the manual.
Oct 20, 2008 | 1994 Chevrolet S-10 Blazer
Alpine CDA-9883 CD Player Logo
50 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
