Sony NW-E107 MP3 Player Logo
Posted on Sep 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Random! when i first got it it was perfect but then after awhile my random function stopped working! it just keeps playing the same random as if it is a playlist! everytime i put it on random it just play the song in the same order as before !
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on May 30, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2175247
Points
14133
Reset the player. Reformat the player. Recover the player. Upgrade the firmware. If it still doesn't work, give up. I hate to be like that, but that is all you can ever do with any Mp3 player. I work for an mp3 manufacturer, I should know.
-Tha (jaded and weary) Mp3 Doctor
2answers
Ok the manual didn't tell me much I just need to find out how to work the CD player on a sylvania scr4986. Can someone help me. I'd really appreciate it.
Basic CD Operation:
1. Power the unit ON if STANDBY mode by pressing the STANDBY ON/OFF(#3).The default
mode is RADIO,so press the FUNCTION button(#8) to switch to the CD mode.
2. Open the CD door by pressing the OPEN/CLOSE door release button(#9).Inset a CD with the
label facing upwards and close the door.
3. The unit will read the disc and display the total number of tracks found on the disc on the
display
4. To begin playback press the PLAY/PAUSE/BAND button(#1).The first brack on the disc will
play.
5. To pause playback press the PLAY/PAUSE/BAND button(#1) once more.Pressing again resumes playback.
6. Press the STOP button(#2) to stop playback.
7. Use the AL 1/VOL- or AL 2/VOL+ buttons(13,14) to adjust the volume level.
Advanced CD operation
1. Press the FWD/TUN+ button to skip to the next track.Press and hold to fast forward the
current track.Release the button to resume normal playback.
2. Press the REV/TUN- button to skip to the previous track.Press and hold to fast rewind the
Random playback
1. Press and hold the SLEEP/RDM button(#15) either during playback or in STOP mode for 2
seconds and then release.You will see the letters RDM appear on the display to indicate the
RANDOM mode in active.
2. If you enable the RANDOM function in STOP mode,press the PLAY/PAUSE/BAND button
to begin playback.If you enable the function during playback the next track will begin the
random order
3. To cancel the RANDOM playback mode,press and hold the SLEEP/RDM button(#15) for 2
seconds and release again.The letters RDM will disappear from the display to indicate the
function has been cancelled.
Repeat function
1. Before or during playback press the REPEAT/PROG button(#6) to repeat a single track
indefinitely.You will see REP appear on the display when active.
2. To repeat all tracks on the disc,press the REPEAT/PROG button(#6) twice(or once more if
you have already activated the repeat once function).You will see REP on the display blinking
to indicate the repeat ALL function is active
3. To cancel any repeat modes,press the REPEAT/PROG button(#6) once more(if in repeat all
mode or twice if in repeat once mode).The letters REP will disappear from the display.
CD program playback.
NOTE:You can only program a playback sequence while the disc is in STOP mode.
1. Press and hold the REPEAT/PROG button(#6).You will see P01 appear on the display to
indicate the program function has been initiated.
2. Use the FWD/TUN+&REV/TUN- buttons to select the track you want to play in slot No 1.
3. Press the REPEAT/PROG(#6) to store the selected track in slot 1.The display will now
display P02 to indicate your selecting the track for slot 2.
4. Repeat steps 2 to 3 for every track you wish to program up to a maximum of 20 tracks. If you
try to program more than 20 tracks the display will revert back to P01 and will overwrite the
first slot again.
5. Press the PLAY/PAUSE/BAND button(#1) to begin the programmed sequence playback.
6. Should you wish to cancel the programming you can press the STOP button to resume normal
function.
How do I use the random orbital sander?
Random orbital sander is relatively easy to use and control. You can get a lot of work done using a random orbital sander by spending a little amount of time. But, there are some things that you should keep in mind to get the best use of the sander. In this article, we are going to show you how to use a random orbital sander to its full potential.
There are many brands out there in the market right now. Each offers a different style and different controlling functions. But, the core elements of each of them are the same. The random orbital sander gives you the free and easy usability. Plus, the finishing that these sanders provide is unparalleled.
THE USE OF RANDOM ORBITAL SANDER
You can use a random orbital sander to achieve versatile woodworking functions, but mainly it is used to give your material a more smooth texture. Usually, these tools come with a lot of power so you can work on rough materials and get quick results. The design is very compact so that you can work with ease, even with one hand. So, ultimately this is a sander that will give you great power and control in a compact body.
HOW SHOULD YOU DEAL WITH THE TOOL?
Keep the Object Locked
Make sure that the object that you are working on is properly locked. Keep it secure, so it does not move too often. This way, you have had more control over the job.
USE EVEN STROKES: You should apply even strokes in every part of the object to make sure that they are sand properly. This will result in a smoother finishing to your object.
USE VENTILATION IF NEEDED Try to remember this when you use a random orbital sander, keep the ventilation on. It creates dust particle that cannot be easily controlled. So, you should keep your ventilation on to avoid the debris in your mouth.
CHOOSE THE RIGHT KIND OF SAND PAPER Different kind of wood respond well to different kind of sandpapers. So, you should look out for what is best for you and then buy your sandpaper accordingly. Make sure to properly place the sandpaper on your sander and that your sander head is clean at the start.
DOUBLE SAND THE EDGES: It is always a good idea to double sand the edges if you are looking for perfection. This allows the object to have a more fine tuning and luxurious look.
THINGS TO KEEP IN MIND:
  • Do not change the disk of random orbital sanders very frequently as it will not be cost-effective. Use it until the very end.
  • Do not apply too much pressure while working on the edges
  • Add vacuum if you want to keep your station clean.
  • Sand with a steady hand and turn up the power for rough woods.
Source: Detailed Guide On How To Use Random Orbital Sander
1helpful
2answers
I have a coby mp828 and I am trying to shuffle songs. I have the random function highlighted and it still won't shuffle..Any ideas
Start playing a track. Click anywhere on screen. Options should show at top of screen. Click on the tool symbol (should look like a bolt.) Click on repeat mode. Click random. This should solve your problem.
Buttons on the remote of my new undercabinet TV work only on an intermittent basis. I am unable to start at the 2nd or 3rd title of a DVD. Have not yet been able to make the ''Go to'' + ''number keypad''...
My new TV/DVD doesn't work. I went to the indicated GPX website for help, and all I get is a solicitation for a subscription assistance plan. Beautiful: misdirection, subterfuge and confusion. Smoke and mirrors. The new American way.
2helpful
2answers
Omni mp4 ga602 model. how do you get shuffle mode. No instruction
Get a song playing. Click menu and a menu, starting with Repeat will come up. Click play on Repeat and a new menu will come up. About two thirds the way down is Random. Click play on random AND Bob is your Uncle.
Random play on GPX ML648B
When a song is playing, hit the Menu button and select Play Mode - turn it off of repeat
CD player won't play random
the most likely problem is a weak or failing optical pickup. try a cleaning disc first there may be dust on the lens. do not use any liquid to clean the lens. remember this is an optical system if it can't focus properly or "see well" it can't read.
4helpful
2answers
Remove random play
go back all the way in the menu till you get to the begining and select music library, then go back to play mode and select normal
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
