Question about Epson Stylus 680 InkJet Color Printer
Epson Printer CX5400
My printer bites and it started to print some colors than none - anywho I researched it on the net and read to clean the purge tube - WELL IT BROKE.....I have the printer apart and need another - where can I find one...it is a small little tube that holds the ink and the ink flows through when needed without it I cannot put the printer back together...just need the tube...any ideas where to get it? Really appreciate it...I am hopeful that once I get another tube this printer will work - Thanks in advance, Maggie
  • Epson Master
  • 705 Answers
Take the broken tube with you to somewhere that sells tropical fish. The tube is a silicone type but almost anything will do if it is fairly soft. Most fish places have similar tube for air in tanks.
Posted on Apr 02, 2008
SOURCE:
Epson Stylus CX5400 will not print. This printer was unused and stored for 3 years. We replaced the ink cartridges and cleaned the print head and aligned the print head and ran a nozzle check. The printer...
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!You might have dried it up.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 11, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Printer not printing colors
Your issue is probably the waste ink tube having popped off. More information HERE and fix HERE.
Feb 27, 2008 | Epson Stylus CX5400 All-In-One InkJet...
My Epson Stylus CX5400 won't print.
hii,
u printhead block..that why cannot ink cant not get trough from the print head..or try clean the print head using printer properties under maintenain .for informations epson print head are sensetif..
Oct 25, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400 - use as scanner only?
imy cx5400 prints only part of the page.it also prints so light i can barley read it.When Iprint pictures there are lines all down the picture.
Aug 30, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus cx5400
Please help....My scanner only shows a large corner portion of the copy. The menu reads ERROR
...no color CYAN etc etc I have contacted many technitions....None have helped The last person Claimed it had to do with low ink....It doesn't make scence. Isn't the scanner separate from the printing components?The printer is in excellant condition...but I was told to dump it and get another I do hope you can HELP....I am 83 yrs young and I have a budget problem....Many Thanks Phyllis
Jul 27, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Printer only prints blank pages epson sylus cx5400
Sorry to say, but you may want to read this thread......
http://www.fixyourownprinter.com/forums/inkjet/29681
Jul 12, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 prints bands of color
directly hooking the printer to mac and windows computer are you getting bandings still? interesting issue... we will isolate it first by trying to hook printer directly to both computer, if its printing fine when directly connected, then there is something on the application or communication process. try printing a different document using same application when on the network and try printing from different application as well. update me afterwards..
Apr 03, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Not printing in color
Hi-
Chances are the tubes are clog and you need to dismantle the printer to clean it, if you have tried cleaning the heads several times then nothing change. Might as well have it service or buy a new one, call epson customer service- 562 276 4382 or 1300 so that they will offer you the loyalty website and you can get a new epson printer, discounted in price.
Hope this help
Nov 03, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus cx5400 all in one ink jet printer
This unit has a built in cleaning routine. Also make sure you are using genuine HP OEM carts. You can also blot the cart jets with a damp bounty paper towel. Fold the damp towel to make it thick. Then just press it against the jets a few times to make sure a good flow of ink is blotting the towel. Then put it through a cleaning cycle.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 03, 2007 | Epson Stylus CX5400 All-In-One InkJet...
My Epson 680 Printer only gives me blank pages
First of all, there is the seller's liability here. If it's from eBay, there's some protection feature for you to use. The "prints blank pages" problem is believed to be caused by a clogged purge tube. Here is a guide I found that exlpains the problem, and how to solve it: Recently, after changing out the blank ink tank on my finacee's Epson CX5400 multifunction inkjet printer, the printer began printing nothing but blank pages. Even after doing multiple head cleanings and test prints, pages would emerge from the printer completely blank. After some research, a number of fellow CX5400 owners have reported having the same problems, to the extent that the term "design flaw" became a common theme. I've owned several Epson printers and have had, generally, good luck with them. I was always somewhat suspicious of Epson's philosophy of making the print heads a permanent part of the printer and having the only replaceable part be the ink tanks, but it produced good-looking prints so it didn't bother me. Now I know, unfortunately, that this system is both a blessing and a curse. Before we delve into how to fix your blank-page-printing problem, a quick explanation on how Epson's ink delivery system works (or, rather, how it appears Epson's ink delivery system works, because Epson isn't exactly willing to divulge its trade secrets) is in order. There are a few components to the delivery system. First, you have the ink tanks. Early Epson tanks were just that; plastic boxes with a sponge inside saturated with ink. Newer tanks have a small PCB with a flash chip on it, so the printer can tell if a tank is new or used, or if it's an Epson brand cartridge or a generic replacement. In either case, the basic functionality is that it's a holder for the ink. Next in the chain are the ink tubes and primer. I've heard conflicting reports on how Epson printers get the ink out of the tanks; some believe that the tanks are positively pressurized when first installed, so that ink shoots out of the tank when the printer needs it. Other reports say that the printer puts negative pressure on the cartridge to draw ink out of it. Once the printer has the ink out of the cartridge, there are two places it can go, to either the print heads or to the purge tube. The print heads are what makes the ink spray onto the paper; the purge tube is where the ink goes when the printer primes new cartridges and cleans dirty print heads. Many cases of the "prints blank pages" problem occur right after installing new ink tanks. People have literally removed empty tanks from printers that work perfectly, and installed new tanks to find that the printer delivers blank pages (this happened to me). Since it's highly unlikely that the print heads have become clogged during the 5 minutes it takes to swap out the cartridges, the problem has to be elsewhere in the ink delivery system. So here's what happens when you install a new ink tank: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The ink flows through the purge tube into the internal absorbent pad. 4. After a couple seconds, the printer stops the priming sequence and probably does a quick print head cleaning. Now, a few people have done some in-depth troubleshooting and found that the "prints blank pages" problem is actually caused by a clogged purge tube. While this may not immediately make sense (you may be thinking, "so what if the tube is clogged, the ink will just spill inside the printer elsewhere"), here's what my research suggests happens when the problem occurs: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The tube is blocked, so the ink has nowhere to go. 4. After a couple seconds, the printer stops the priming sequence. Epson's ink delivery system appears to be a sealed system, so when the ink has nowhere to go in step 3, little ink has actually escaped the new ink tanks. This means they're not primed correctly, and won't deliver ink as they need to when the printer goes to print. So unless the purge tube gets cleaned out, you can swap tanks and perform head cleanings until the cows come home and it won't do any good. Now that there's a basic understanding of what's going on, here's how to try to fix the problem. This guide is meant to be model-agnostic; I did this procedure to a Stylus CX5400 multifunction, but it should be similar for most Epson inkjets made in the past few years. It's unknown if new Epsons still have this problem, as it usually takes a year or more to surface. The first thing you need to do is prepare your work surface. You'll need a big table, preferably one you don't care too much about. If all you have is your good kitchen table, then it's a good idea to slice open a tall kitchen garbage bag to make one large sheet, and tape it to the table to protect it. Next, you'll need the following tools and supplies: (View attached picture)
Jun 21, 2006 | Epson Stylus 680 InkJet Color Printer
Epson Stylus 680 InkJet Color Printer Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
