Question about Nintendo Wii Console
Power just bought new WII - plugged in - but no power light comes on. Checked fuse and retied a different socket - but no power.
  • 56 Answers
Return to store you bought from , or contact seller. if it's new, they should return and replace it.
Posted on Sep 12, 2007
SOURCE:
Wii suddenly no power
I have had this problem. But for me it was were for some reason if power to home goes out and comes back on (due to weather or really anything) the wii will not work ever again in the same wall socket. the wii reacts this way for reasons unknown to me, but when I plugged it into a different socket even on the same outlet it works. what i do now is keep it plugged into a surge protector and turn off protector when not using wii. I hope this is your issue, if so the wii will still work fine in another socket. only other advice I can give is to buy a new power cord, and if that does not work then then smell the vents on the system and see if it smell like burned wires. if so your power supply has burned out and the system will need to be serviced. I hope this helps.
Feb 27, 2013 | Nintendo Wii Console
Wii wont turn on, nothing had a lightning storm last night and now nothing
Try replacing the power cable, many times when there is a power surge and you do not have a surge protector it will burn out the transformer on the power cord. If you replace it and still nothing, most likely your Wii has been burned out by a power surge.
Feb 28, 2011 | Nintendo Wii Console
System will not turn on
Can you borrow a friends power supply and try it? I presume you checked the fuse in the plug socket (If a UK plug.).
There is a fuse in the power supply which could have blown.
There is also a fuse on the power inlet on the Wii motherboard (it is coloured green). That could have blown.
After that there are over 40 fusable links on the motherboard!
Jul 24, 2010 | Nintendo Wii Console
Power will not come on at all a cable guy came to my house turned cable off to reset it my power went out and some sparks came out of some outlets next day my son went to play wii it would not come on....
1. Try plugging something else into the socket to ensure the socket itself is working.
2. Changing the fuse in your Wii power adapter, blown fuses are very common and this could be it.
3. If number 2 doesn't work try and get a hold of a replacement power adapter as the problem could be a break in the wire.You can get a new adapter at this site NDSL games console, ds games console, NDSL games console_Video games Console_www.goldenbridge.hk
Mar 20, 2010 | Nintendo Wii Console
My Wii console want come on at all. I have diconnected all the cables and reconnected them and the power light still want come on. What can I do or should I just send it in for repair.
3. If number 2 doesn't work try and get a hold of a replacement power adapter as the problem could be a break in the wire.If it is the fuse then you can buy one at this site.NDSL games console, ds games console, NDSL games console_Video games Console_www.goldenbridge.hk
Mar 01, 2010 | Nintendo Wii Console
Our wii console won't turn on. The power button doesn't even glow anymore. What's wrong with it?
it might be a problem with the power converter. make sure the wall socket the wii is plugged into is working properly and you don't have a broken fuse somewhere. try a different plug to see if you can get the wii to power up at all, if not you might need to buy a new power cable.
Jul 31, 2009 | Nintendo Wii Console
Power problem with nintendo wii
Lets Hope So ?
Check the main fuse in the 3 Pin plug ( if UK )
replace if blown, also check the wires are tight to the plugs pins.
Is There any light Indication On The power Pack/Brick with These ?
Could be a faulty Power Pack.
Check the leads are firmly connected, quite easy to knock a cable out, with an accidental kick or push of the console et,c.
Mike @ Compurepair.
Feb 28, 2008 | Video Game Consoles & Games
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
108 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
