No picture,great sound.Did try two things to fix.A hard reset..aka unplugged for 6 hours,also gave it an old school whack.Picture came back on but a few hours later a red flash /line happened then screen went dark,but the sound still good.Any clues?
Vertical output chip has some ring cracks on leads (cold solder joints). Set is shutting brightness off to protect5 it's crts from burning a black streak across them.
water spilled on right rear side near cable inlet connection. when plugged in standby light in front...
(More)
water spilled on right rear side near cable inlet connection. when plugged in standby light in front remains on and constant. no picture and no sound.
I have a hcm5525w projection tv. my problem is that it rarely turns on once it has been turned off....
(More)
I have a hcm5525w projection tv. my problem is that it rarely turns on once it has been turned off. I try turning it on throughout the day. I've also tried unplugging it and waiting 30 seconds then replugging it in, but I always get the same result... the red power light flashes and clicks as if it was trying to turn on but nothing ever happens. every time it does happen to work and come on I have to leave it on constantly because if I dont, it stays off and never works for close to a month or so.. except for this time, it hasnt come back on for probably 3 or 4 months. unfortunately I havent had the funds to take it somewhere for repair. so any help or suggestions you could provide me with would be greatly appreciated. thank you
