2000 Ford Mustang Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stereo won't turn on - Ford Falcon AU Ute (2000)
I think it is a blown fuse, but the fuse schematic is gone from the panel, so i don't know where to start - any help greatly appreciated.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 259 Answers
  • Posted on Apr 05, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
259
Questions
0
Helped
123330
Points
734
The easiest way is to check all the fuses is it only the stereo that won't turn if so it could be something else fuses usually control 3-4 things from my experience hope this helps regards Jim
Manual for ford falcon au ute v6 2001 pick of fuses
go to www.manuel for 2001 ford falcon it can downloaded free Good Luck
How do i bypass the smartsheild on a 2001 au ford falcon ute.i cant start because the smartsheild comes on an jams the motor?
the problem was raised in the australian AU ford forum not so long ago
you cant bypass it
ripping out wires without knowing ... just causes more grief
have to use a scanner to re set system
or find which module of the smart shield has failed
AuII Smartsheild question
fordforums com au
i have the downloadable repair manual for that AU
one download only.. not for resale etc etc
Ford Falcon AU 1998 2002 Workshop Manuals Factory Service Manuals
When I stomp on my brakes let's say in an emergency the pedal is very hard and the brakes don't realy work at all but if I use them normally they are perfect it's on a ford au xr6 ute
to test your brake assist is working. stop the motor. Press w few times the brakes, till the pedal feels sturdy. Then while pressing the pedal down firmly, start the engine. When you feel the pedal going down, like feeling "soft" you know the brake assist works. If nothing changes it is defect.
1helpful
AU Falcon turn over no fuel pump no start could it be the transponder in key
Check fuel cut-off switch if fuel pump is not turning on and you have checked the fuses.
2answers
Where do i find the flasher unit in 2000 au ford falcon
It's in the Fuse / Relay Panel near your right knee. find-flasher-unit-in-2000-au-ford-falcon-1rbchycbcuybl1cpyyfgiayi-4-0.jpg
2helpful
My auto blow up in my au falcon so i got a sec
any instrument service centre will be able to adjust or suply the required speedo gear to put it right youdoit
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
