Question about Fossil Watches
Fossil Watch Repair
The watch is made by ARKITEKT and item# FS-2693. The back clamp of the watch is broken and need a new one it a double clamp that closes from left and right into the middle. Can you you help me? NO0877
2 Suggested Answers
  • 43 Answers
SOURCE: remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Posted on Jan 14, 2009
  • 2501 Answers
SOURCE: I am trying to find
You can get links from the maker.
Go to and you will see a menu on the left.
Under "Product info" you will see "ordering links and bands", click on this and follow the instructions.
Posted on Jan 08, 2011
0 characters
1 Points
What battery size does a fossil arkitekt fs-2759 take? Thank you
Just take the watch to your nearest jeweler. They can quickly replace it for you....probably cheaper than what you would pay for the battery yourself.
Mar 02, 2015 | Fossil Watches
I am trying to find extra links for the band, it is too tight, I need 2. I have searched all the web sights I can find with no luck. The watch is a Fossil ARKITEKT FS-3003.
Jan 08, 2011 | Fossil Watches
I don't have the original battery to my watch, and am looking for a replacement. The watch is a Fossil Arkitekt FS-3031
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href=""></A></P><P>Best regards.</P>
Aug 24, 2010 | Fossil Watches
I have a Fossil Arkitekt wristwatch (FS-2919). on of the hands on one of the three tiny dials has come loose and is floating around the face. I probably wouldn't care, but the main watch hands get caught...
You will have to remove the back off the watch (cant take off the face). You MIGHT be able to access the hand from there, but you may have to adjust some of the watch inner movement and that will be risky but you can try.
Goood luck
Aug 21, 2010 | Fossil FS2919 Wrist Watch
Fs 4159 sudennly stopped working
The first thing to check is the battery.
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Feb 25, 2010 | Fossil Arkitekt watch
Can't find the watch band for fossil arkitekt fs 4127?? it have a curve and use two pins
I have the same watch Fossil FS-4127 and I too can't find a replacement band. Appears to be planned obsolesence by Fossil. This FixYa site is almost as bad as Fossil, which is all advertisements and no answers whatsoever.
Jan 03, 2010 | Frontgate Watches
Lengthen band
to make longer have to add a link-contact them 800-842-8621 will ask for info on back of watch
Nov 26, 2009 | Fossil Arkitekt Stainless Steel ! Watch...
On most watches, if you get condensation within the face, means that there is a small crack on the glass/plastic covering. Some watches you can take apart from the back and pull out the workings and replace this casing, on others, you have to take it to the jewelers to have it replaced. Depending on how much you paid for the watch, you are better off buying a whole new one.
Sep 20, 2008 | Fossil BQ9184 Wrist Watch
Watches Logo
122 people viewed this question
Top Fossil Watches Experts
Arturs Kalnins
Arturs Kalnins
Ray Murphy
Are you a Fossil Watch Expert? Answer questions, earn points and help others
