Question about LG VX5300 Cellular Phone
Replacement Antenna for LG VX5300
I purchased a replacement antenna for my LG VX5300 (the antenna is part number snmf0022401). However, the antenna came in a plastic bag with no instructions on how to remove the old, broken antenna and install the new one. I checked LG's website, but could find no self-service instructions, let alone any hints on how to replace the antenna. Do you know where I can find such instructions?
  • Anonymous Dec 19, 2007
    I have the same problem. Did you find out how to replace the antenna? Does it unscrew?
It is pretty simple to replace. You have to unscrew the back of the phone and remove/replace the screw that holds the antenna and the connector in place. Then screw the back of the phone back on. I don't know where you order the part, but if you find out let me knw since I need another antenna.
Posted on Mar 03, 2008
Thought I would ask if anyone has figured out how to replace the antenna on the vx-5300? Mine broke and I would like to replace it. Also, where did you get the part number for the antenna and where did you buy it? Thanks.
  • 89 Answers
Well.. few old mobile phone antenna was easy to remover i remmber old day when my father use to own Erricson moble phone you can can the antenna and plug it out simply up wards but new phone i heard that we must unscrew them to replace the problem . better get it to the repair guy . i am sure he won't charge you much for this
Posted on Sep 03, 2007
SOURCE:
Garmin Quest antenna broke of while quading need new antenna where to?
The best thing I can recommend is shop around on Ebay and hopefully find a basketcase Quest or Quest 2 with the antenna intact. Swapping the antennas is fairly easy. Lay the GPS display side down and remove the two endcap screws on the right side. Pull the old antenna out and to the right and replace it with the replacement antenna. Another option you may try is purchasing an external patch type antenna that can mount remotely and plugs into the back of your Quest GPS. Garmin WILL NOT sell you a replacement antenna. They want you to send it to them for repair and will charge you $100+.
Oct 05, 2010 | Garmin Quest GPS Receiver
Where can you purchase a replacement antenna for
I just replaced my broken antenna for my CFD-S350 by calling Sony Parts and Support at (239) 768-7691. Cost only $7.99 and that included the $2.00 shipping charge.
Jun 03, 2010 | Sony CFD-S350 Radio/Cassette/CD Boombox
Where can I purchase a replacement antenna?
I found mine at a every things a dollar store. You could try radio shack or an electronics repair store.
Mar 28, 2010 | Eton FR250 FM/AM Radio
Grundig YB400PE broken antenna
Unfortunately, your description of the problem means that your radio must be taken apart to be fixed. Replacement antennas can be found purchased. It would require installing the new antenna and most likely soldering it to the broken wire. Do you have a picture?
Apr 05, 2009 | Grundig YB 400PE AM/FM/SW Radio
Replace power antenna
its held in by the bracket on the botom of it and also the chrome nut arount the top of it... remove the nut from the top and the bolts from the base support bracket and then remove the antenna and power wires.. when installing replacement antenna secure the top nut first. then bolt base and reconnect antenna wire and power plug
Feb 24, 2009 | 1998 Cadillac DeVille
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Lg vx8350 Using external antenna port. Phone now refuses to switch back to internal antenna when external antenna is unplugged. No signal now without external antenna. Plug external antenna back in, full...
The Wilson adapter damaged your internal antenna. I talked to Wilson today to get a part number to buy the adapter and the told me they did not recommend using it as it has damaged a number of phones. They also said that LG might have corrected the problem in the newest production models.
Oct 13, 2008 | Lands Phones
LG VX5300
There is no way to tighten it. You say you've had it for about a year. If that means you've had it less than a year and it's under warranty, take it to your provider for a repair or replacement before the year is up. I'm sorry this is probably not the answer you wanted to hear.
Aug 24, 2008 | LG VX5300 Cellular Phone
The antenna is broken at the base eye, and repeated attempts to re-attach the eye have failed.  How can I purchase a replacement antenna?
It's possible to get the same antenna on ebay...
You can check here:
http://item.express.ebay.com/Consumer-Electronics_MP3-Players-Portable-Audio_Boomboxes_Boombox-Radio-Replacement-Antenna-12-Inches-Boom-Box_W0QQitemZ120194279381QQihZ002QQptdnZBoomboxesQQddnZConsumerQ20ElectronicsQQadnZMP3Q20PlayersQ20Q26Q20PortableQ20AudioQQptdiZ493QQddiZ945QQadiZ500QQcmdZExpressItem
or here
http://item.express.ebay.com/Consumer-Electronics_MP3-Players-Portable-Audio_Boomboxes_Boombox-Radio-Replacement-Antenna-12-Inch-Sony-RCA-Coby_W0QQitemZ120194280040QQihZ002QQptdnZBoomboxesQQddnZConsumerQ20ElectronicsQQadnZMP3Q20PlayersQ20Q26Q20PortableQ20AudioQQptdiZ493QQddiZ945QQadiZ500QQcmdZExpressItem
Dec 02, 2007 | Jwin (JX-CD512D) Sports Portable CD Player...
Replacement Antenna
antennas are not so strict part of an audio equipment, you may replace with one available, with the same size, eventhough not the same length.
May 20, 2007 | RCA RCD152 Boombox
LG VX5300 Cellular Phone Logo
307 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
