Question about Garmin StreetPilot 2620 GPS Receiver
Messed up with garmin
Well i cant use my touch screen, today i tryed fixing it by telling the garmin to disable the remote, well it didnt work so now how do i get my remote to work agai since i cant use the touvh screen!!
  • Anonymous Aug 11, 2008
    My remote too has stopped working. I was doing some re-sets to the unit and I "think" I came across an option for REMOTE.. and (don't ask me why) I set it to off.... now I can't find the option again... have you fixed yours yet?
    Scholar:
    New Friend:
  • 39 Answers
I wasn't able to get this to work for me. Previous attempts to restore the touchscreen has worked only to have it fail shortly thereafter. I think there is just a bad touchscreen issue with 2620s and the controller. I have noticed it is possible to resurrect one from not working at all and simply power cycle and calibration and using the device seem to do that. I wish Garmin would release the internal help stuff since they have stopped supporting this unit.
Posted on May 01, 2010
  • 3 Answers
(1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored.
Posted on Sep 08, 2007
6ya staff
SOURCE:
I have a garmin nuvi 250 and the touch screen is not responsive. I tried to recalibrate it by turning it on and holding the power switch for 30 seconds and touching the screen and the calibration dot came...
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If there is a software update available, that should solve your problem.
Mar 31, 2017 | Garmin nuvi 250 GPS Receiver
The screen on our gps is messed up! Either it got
You would have to send it to Garmin unless you found a Marine Electronics dealer that had an old display in their shop. They could then replace your display. Good luck!
May 22, 2010 | Garmin Gpsmap 5012 Touch Screen...
My touch screen stopped working, how do i fix?
I got the same problem have you found a solition yet? I cant get to the settings to recalibrate it
May 19, 2010 | Boss BV9555 Car Video Player
My garmin 255w's touch screen is messed up
There are three ways to fix it
Recalibrate
remove face cover and use the reset button or the sequence from the manual to reset factory settings
Finally.... send to Garmin
Aug 18, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 680 Touch Screen not working
You dont have much option, if the touch screen failos or becomes intermittent then its dying or dead and can only be fixed by a total replacement
Cheaper to buy another GPS
Jul 24, 2009 | Garmin Nuvi 660 GPS Receiver
Touchscreen not working
umm.. i didnt see the video, but go on www.youtube.com and just search "how to fix touch screen". there should be videos that tell u how to fix it. i didnt see the video since my DS didnt have that problem..HOPE THIS HELPS!!!!!!!!!!!
Jan 24, 2009 | Nintendo DS Lite Console
My GPS system is having seizures
The solution is listed on the garmin site but it is not clear
The problem is with the infra red remote reciever on the unit
Sometimes the sun acts like the remote is being pressed and that is when it shakes
the solution, and I hope you still have the unit cause there is nothing outthere like it.
Answer: from garmin site Normally this issue is caused by sunlight from certain angles hitting the Infrared (IR) port on the unit. This makes the unit react as if the remote control was communicating with it. This makes it switch in between screens just like if you were using the remote.
You can disable the remote IR port on your StreetPilot® 26xx unit by:
  1. Powering your unit ON
  2. Press the Menu button
  3. Touch Options
  4. Touch the General tab
  5. Press the Menu button
  6. Touch Disable remote
If you wish to use the remote again you can enable the remote IR port on your StreetPilot 26xx unit by:
  3. Touch Options
  6. Touch Enable remote
http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=2610+remote+off
Dec 26, 2007 | Garmin StreetPilot 2610 GPS Receiver
TOUCH SCREEN
Try recalibrating the touchscreen
Sep 14, 2007 | Garmin StreetPilot 2720 GPS Receiver
Garmin Nuvi 660 - Bluetooth
I fix this problem for my Nuvi 660 Europe. I found resources in Italian language only: 1 - go to http://www.garmin.it 2 - in the search texbotx (i the up left corner of the page) type bluetooth and press enter 3 - click on the 1st faq that will appear 4 - download the file FileBluetooth.zip 5 - unzip the file 6 - copy 006B055301.GCD in X:\Garmin\RemoteSW directory 7 - reboot your nuvi At this poin bluettoth would be ok newly. Bye
Aug 08, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin StreetPilot 2620 GPS Receiver Logo
381 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
