Pioneer DV-545 DVD Player
Problem for Pioneer DV-545 DVD Player
DVD picture cuts in and out first 15 minutes
By early on Sep 03, 2007
I have a brand new Pioneer DVD player, model CD400VK which I have hooked up to my brand new Sony Bravia KDL46XBR2 flat-screen, LCD digital color TV. My problem is that whenever I watch a DVD, only within the first 15 minutes, the picture cuts out for about 10 seconds and then resumes, but about 4 minutes later, it does it again. After 15 minutes of running time, this doesn't happen anymore.
I have already exchanged the Pioneer DVD player at the store, but the problem persists.
Do you know what could be causing it? What should I do to fix it? Sony Customer Service tells me that if the picture doesn't cut out while watching TV, then the problem must lie with the DVD player.
Could you kindly let me know what you think? Thank you.
P.S. My PIONEER product is actually model DV-400V-K, but it was not part of the selection list, so I had to pick the closest model number (DV-545) to get past this screen.
Solution #1
posted on Nov 08, 2007
Not Rated)
SnowHarp
Rank: Apprentice
Rating: 0%, 0 votes
This is like the problem I had for some months. After a lot of exchanging cables and troubleshooting on forums like this, I decided to call in the Sony service engineers.
The problem turned out to be nothing more than a menu selection. You need to check the setup menu under video and select the colour system you are using (NTSC, PAL). The factory setting on the TVs is 'auto' apparently and sometimes a weaker signal will cause the auto colour setting to drop in and out. In our case we set it to PAL and the problem has not recurred.
Was this helpful?
Yes
No
Popular Solutions for Pioneer DV-545 DVD Player
Questions and Unsolved Problems for Pioneer DV-545 DVD Player
Do you recommend Pioneer DV-545 DVD Player?
Answer
Answer
fix my sony BDP-S550 to be region free
Answer
Will not read blank DVD's. Willnot initialize recordable DVD's. Always reads disc error.
Answer
Lost recording when using epg - having set programmes to record with the EPG, recording then does... (More)
Answer
My DV-555k used to work well, but now it always shows "NO DISC" sign after loading a... (More)
Answer
my dv-555k always shows "no disc" sign and scratches DVDs so they can't be played again
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
