Question about Canon CFX-L4000 Plain Paper Laser Fax
I cant recieve an incoming fax
I an only send a fax not recieve
  • Anonymous Mar 19, 2008
    hi
    i send fax transmitting ok, but i cant recive the fax .
    Scholar:
  • 159 Answers
Check receive mode, probably set to manual receive.
Posted on Dec 25, 2007
Uncheck the manual and the answer hook up lights.
Put your phone jack into the line on the left of all 3 = L
ureka it works!
3rd times the charm-
Posted on Jun 26, 2008
5 Suggested Answers
goalie39
  • 469 Answers
SOURCE: Black pages on every fax I send
Is sounds like your exposure lamp is not coming on, put an original in the machine and make a copy, if you look where the original is coming out, you should be able to see a light illuminatig the original so the scanner can read the image. If this lamp is not coming on you will get a very dark to black image.
If it is just locked up is may be as easy as this. Turn off and unplug the machine for a couple of minutes, reconnect and power up the machine, make a copy. as the machins uses the same parts to copy you should see the result of your efforts.
If the copy look good, try a test fax to someone, and call them for confirmation.
If this doesn't fix the problem, then I suspect the exposure lamp unit has failed.
Hope this is of some help.
Posted on Apr 17, 2009
SOURCE: fax can not recieve. It sends okay. Hp fax 1010
Most likely the machine has been set to "manual receive" from either "fax/tel" or "automatic" receive. check your manual to check/ change the setting.
Posted on May 26, 2009
redzventures
  • 149 Answers
SOURCE: I can send fax but cant recieve fax
You have not told us which model fax you have but most machines have a receive mode selection. Your machine may be set to 'manual' receive. It will only receive if you pick up the phone and hit the start buton. The phone has to be connected to the machine. Look on your machine for the receive button. It may be marked as 'auto receive' and 'manual receive'. Select 'auto' so the machine will answer. It may be marked as 'fax mode' and 'tel mode' if so select 'fax mode''. It may also have a selection 'ans mode' you don't want this as it assumes that you have an answer phone connected to your machine and it waits until the machine answers before it detects incoming fax. Good Luck
Posted on Jul 08, 2009
SOURCE: can't receive or send faxes. Incoming faxes
error message 71 unplug and call brother
Posted on Feb 12, 2010
Hoe do I set up fax functions on Canon Pixma MX452
My incoming fax issue was resolved when I enabled the answering machine function on my phone. All this time my answering machine was turned off. I have yet to send a fax. My model is the Canon Pixma MX452.
Apr 05, 2013 | Canon PIXMA Office Equipment & Supplies
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
My brother intellifax 4100e is not recieving faxes we can send and I called the fax it works and we can copy but cant recieve.
Does the machine actually answer the incoming call? If so does it give an error code? Are you using the genuine brother line lead? Finally make sure the line lead is plugged into the "line" socket and not the "tel" socket.
Aug 15, 2011 | Brother IntelliFax-4100e Fax
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
Cant send faxes or recieve
Do you still have the problem?
Did you go through the entire setup procedure according to the manual including the fax/tel set up? Fax/tel setup tells the fax machine how you are using it. For example is the phone line used for just receiving faxes or is it used to receive phone calls AND receive incoming faxes OR is there a telephone answering device (TAD) attached to your phone line. If there is one, set it to 2 rigns. If you have it set to 4 rings the fax could disconnect before receiving the incoming fax. If you cannot send, then it has to be a line problem assuming you went through all the set up procedures correctly. Short of this you may have a bad unit and need to return it.
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printing all document out the back of machine
There is a lever in the back, lift it will divert the papers to the front again. ( looks like a small door)
Dec 09, 2008 | Brother IntelliFax-4100e Fax
Incoming fax freezes system
Try installing the fax controller again, make sure to turn off fax machine, reboot computer and then after trying turning on your fax and send another document.
Nov 18, 2008 | Symantec WinFax Pro for PC
Cant recieve fax
please help me how to switch my machine Brother MFC440cn to fax/tel mode.
Oct 26, 2008 | Brother MFC 420CN All-In-One InkJet...
No incoming Faxes
sir,
first you have to set the fax machine in auto answer mode.so that you can automatically recive the incoming faxes.
Apr 09, 2008 | Samsung SF-515 Plain Paper Laser Fax
Canon CFX-L4000 Plain Paper Laser Fax Logo
221 people viewed this question
old marine
old marine
