sorry I dont know the name of the cable but its flat with orange blue green red and white wires. It has jumper type plugs on it that goes into the motherboard.
I dont know how to place them on the motherboard so that it powers up.
The cable is labled with diff led cables pw, reset, etc.
Do you know how I place them on the motherboard?
The motherboard has 9 PINS in the spot where the cable goes and they are yellow, green, blue and red.
The cable doesnt seem to plug into the logical color spot.
I know the pc will power up if they're in the right place. I accidently pulled it off the motherboard not realizing they were all separated and not one piece. When I took it off I didnt know what order to put them back in.
This is not my pc. I have not manuals and i cant even tell what kind of motherboard this is. M863G
Comments:
Apr 05, 2009
- As it turns out, only the LED's are a problem if their cables are connected the wrong way around. The LED's are diodes, so they have polarity. If you have an LED cable on the right pins, but the wrong way around, then the LED won't light up. It won't hurt anything, either. For the LED to work, line up the black wire on the cable connector with the motherboard header pin identified as ground (GND, or pull-down).
I found this online. I ended up plugging in the red and white wires first as is was the power sw and the pc came on. I connected the remaining wires to their color match. They need to be inserted to the pn1 and pn2 headers so that the metal pieces are facing the middle. The labled part should be on the outside after you plug them in
hey look close to the nearby processorin motherboard there is 9 pin (depends on motherboard) for power and for reset button... close your eyes to motherboard at that place you will find also the name which are mention in motherboard e.g. power and reset in motherboard just plug red wire in power and and green for reset ( depends on motherboard) you an chk manually ...
hi, my computer won't boot up. it has a k8mm-v MSI motherboard. when i start it up, it does not...
(More)
hi, my computer won't boot up. it has a k8mm-v MSI motherboard. when i start it up, it does not display anything on the screen even the bios does not appear and just gives me 2 long beeps. the cpu is still running but no display on screen.
i got a Hp dv2402ca laptop i got a problem in my hard disc prevented me from entering to the system...
(More)
i got a Hp dv2402ca laptop i got a problem in my hard disc prevented me from entering to the system and i need the data stored before.. is it possible to get it?? the technician said after he put it on sata that he can never do because the Hd was in a bad situation, and all data r gone.. can anyone please help me by ways to get data back???? pleaseeee thanks and great rating for helping
my Hp laptop dv2402ca got a message on start up saying that it needs recovery or start normally,...
(More)
my Hp laptop dv2402ca got a message on start up saying that it needs recovery or start normally, start normally is not working and i need the data from the Hd so i can't do recovery after i put it on sata it gives a blue screen too, the technician told me that he can solve the peoblem but the data is already erased and i can't get it back....can anyone help me in a way to get the data back ?? please it's important data ... appreciate any help P.S: the hd is one partition and 120 Gb space.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
