Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60pp9202 sound but no picture
Hello everbody hope someone can help me......I have read through the philips hdtv section and must be missing something. I have read about the ic convergence to be changed. everyone is talking about the picture was off(shifted,not looking right,misaligned). I did not have this problem on my set. Here is a solution i read: "If there was a color problem like convergence then change convergence amps, if no problem before storm, probably verticle output. A 7 pin IC located on rear of deflection board against heat sink that stands up" Is the convergence amps(IC)the stk392-120 everone is talking about. and if so what is the 7pin IC, and does anyone have a picture of where it is. Does it look like the stk392-120 IC. I have already pulled the board out where the convergence IC(stk392-120) are but dont want to operate on it until i am for sure this is the right diagnoses. Help Please.
  • 1 more comment
  • joe-eeee Nov 14, 2007
    where is convergence IC located and its part # ?
  • fix751 Dec 11, 2007
    O.k. followed everyones suggestions and still dont have a working set. changed the ic's(stk392-120) and the vertical ic. still no picture but sound comes out. the tubes were barely someone suggested to change the flyback.....had a tech come by charged $45.00 to look at it and said it was the flyback wanted $350. to repair it I paid new a year ago $800. Anyway got a flyback from a local tv repair shop and now the set just clicks no picture or sound.
  • Edward
    Edward May 11, 2010
    Fix751, Did you ever find the root cause? I am fighting a very similar problem.
Thanks for your help fix751. Will let you know how it goes with this set.
Posted on Nov 17, 2007
  • 1,153 Answers
Sorry no pic, but if you look from back of set on deflection board(board with HV transfromer)big part with about 4 wires coming out going to your picture tubes. Looking close to leftside of board the last IC with heatsink shield standing up has a small 7 pin ic if looking on it you should see TDA8177 or something to that affect. This is the verticle IC. Since you have found the IC's (convergence) then the only thing left is to look for open fuses like 1300, 2004, 1900 etc and see if open. Concerning cost if you buy from these part are inexpensive so it wouldn't hurt to buy all. Rule of thumb, if set has color problem then Convergence IC, if no problem just went out one day while playing fine then Vertical, then the alternative if no sound the audio area, which is not common for this set. Hope this helps!
Posted on Sep 05, 2007
Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television no Picture no sound
Are you getting some kind of high pitched squeel from set when you try to turn it on?
The more you tell me the more I can help.
Nov 10, 2011 | Philips 60PP9202 60" Rear Projection...
Philips 60pp9202 I get no sound, no picture and a chirping noise
Chirping in a phillips is usually related to the HOT ( Horizontal Output Transistor) or the Flyback ( HV Generator having a issue.
Dec 11, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60pp9202 - Sound and OSD, no Picture
I contacted my cable provider and he told me the tv defaulted to antena and reran auto set up I get picture but no sound cable man is coming to fix weak signal hope it fixes sound
I may need parts>>>haha
Sep 21, 2009 | Philips 60PP9202 60" Rear Projection...
Green Screen
Sounds like the coolant in the green picture tube needs changing.
Jan 12, 2009 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202, no picture
If the set has sound the flyback is fine the proble is the SSB witch is the video processor part number 310432716308.
Jul 28, 2008 | Philips 60PP9202 60" Rear Projection...
Coolant 'Plug' for Philips 60pp9202/17f
If you have not lost the clear coolant from the CRT, I would use a silicone based sealant to be the "new" plug. Is there a problem with your old coolant that you would like to remedy?...accordianman
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 43PP8545
The most common problem is convergance amp ic, but with out troubleshooting it's hard to pin point whats wrong.
The quick answer to you problem is critical in what your set was doing prior to it shutting down. Do you remember it having a Color problem like alignment of convergence? Was the sound cutting out on you? Or was there part of the picture missing? If one of these then you could eliminate time and money. To be honest you would save money DIY. You also can call PTS at 18008447871 and get the price on Deflection board or Large Signal, whichever has High Voltage Transformer on it and price. This will save time1.gif troubleshooting2.gif, because it takes the knowledge of knowing voltages, components, etc. Which require skills the average person may not have. Hope this helps!
Oct 07, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
457 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
