D-Link DI 514 Wireless Router
Problem for D-Link DI 514 Wireless Router (DI-514)
Help connecting Cable Internet through D-Link DI-514 Router
By dlclcombs on Sep 03, 2007
Help!!! Please!!! For the past several years I have my d-Link DI-514 to connect three computers at our home. (2 by ethernet cables and 1 by wireless.) This weekend I decided to connect the wireless by ethernet to get a faster connection. When I moved the router down to the computer that also has the cable modem hooked up to it and then ran ethernet cables to the other two computers from the router, I cannot connect to the internet except through the main computer that is first in the connection.
I have tried to PING the IP address and it is not found.
Can anyone help me?
Comments:
Sep 06, 2007
- Thanks! I also downloaded a program, Network Magic, that along with your suggestion got it up and running!
Best Solution
posted on Sep 03, 2007
Very Helpful)
sandrew
Rank: Wiz  D-Link Expert
Rating: 83%, 5938 votes
what may be happening is the wireless pc as it was; needs the dns and ip address flushing, also the pc you connected the router to as you must have conflicting ip addreses
Click start run then type ipconfig /flushdns.
You should ensure that the router is set to enable DHCP to assign ip addreses and make sure your'e network cards on all pc's are set to obtain ip address automaticaly in the TCP/IP properties.
Restart the pcs and type 192.168.0.1 in your web browser and get into your router setings and check in the DHCP section that all pc's have been given an ip address.
If all fails you may need to reset the router
Was this helpful?
Yes
No
Popular Solutions for D-Link DI 514 Wireless Router
Questions and Unsolved Problems for D-Link DI 514 Wireless Router
Do you recommend D-Link DI 514 Wireless Router (DI-514)?
Answer
Answer
everything was perfect during the installation till when i was going to start lan...how can i... (More)
Answer
Old airport card required short protocol. Now it needs me to reboot router about once a day.
Answer
Dl-514 is not connecting to DSL PPPOE. I have keep disconnecting the power cable to reconnect, Seem... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For D-Link DI 514 Wireless Router:
Top Router Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
