Question about Toshiba Satellite A105-S4004 Notebook
Backlight problems Hi My daughter push the cover of my toshiba A105 notebook, with 15.4" trubrite LCD. It still working and I can see a faint image. So the LCD is fine but I guess that the backligth blows up. I am not sure if the problem is on the inverter or the lamp. My question is : Is it possible to change the lamp ? Thanks in advance.
  • 64 Answers
There are companies on the internet that do lamp replacement but it is not advisable for the end user to do this.
Posted on Sep 04, 2007
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
Satellite L500 monitor is completely black. One can faintly see the welcome and password bars
Try to go to Toshiba Power Settings in the control panel and change the lcd brightness from there. If this won't work, this may be an LCD backlight issue and you would need to have a professional to change it for you. If it is under warranty, send it to toshiba for replacement.
Hope this helps.
May 30, 2011 | Toshiba Satellite A100-S8111TD Notebook
Display Shows on External Monitor, but very faint on laptop screen. Bright when first starts up but then as it boots into windows it is dark almost black
It's a bad backlight tube inside your LCD screen if it lights up and then dims down. Replacing the screen would be the most obvious thing to do. Replacing the backlight tube is also possible, but it requires a level of expertise that few of us have.
Mar 17, 2010 | Toshiba Satellite A135-S4527 Notebook
My Toshiba Satellite A105 screen comes on for a little bit, flickers and then shuts off. However I can faintly see the screen, and the laptop works fine when hooked up to the external monitor. Wondering...
If you can still view screen if you view it in an angle or spot a flashlight on screen. Then, definitely it is a problem on backlighting, might be loose connection, inverter giving up or cfl giving up.
Hope this helps
Nov 06, 2009 | Toshiba Satellite A105 Notebook
Screen flickers and dies
You have a faulty LCD inverter board.. Go here for instructions on how to replace and find a new one, or you can search on ebay for one.
Sep 11, 2009 | Toshiba Satellite A105 Notebook
I have a Toshiba Satellite A135 and not sure if blacklight or something else
Your backlight lamp, (Bulb), or the Inverter is bad.
1.General instructions, and photos, for replacement of a typical laptop backlight,
2.Instructions for completely disassembling a Toshiba Satellite A135 laptop. The reason I included this is twofold.
A.It shows, and tells exactly, how to remove the LCD screen from your laptop.
B.It shows you that the following information in link 3, on how to replace an Inverter in a Satellite A105, will work for your Satellite A135.
(At the bottom of this page you will see Page1:: Page2:: Page 3:: Page 4
You are on Page 1. Just click on the white Page2, and so on, to continue)
3.How to replace an Inverter in a Satellite A105,
FIRST! Always remove all power! AC adapter, (Charger), and battery.
Second! Observe anti-static guidelines!
Third! This ain't tough! It just looks hard. Once you see how simple this is, I'm sure you'll agree with me.
May 28, 2009 | Toshiba Satellite A135-S2276 Notebook
Just replaced a cracked screen in a toshiba a105-s4074....when i turn it on i can barely see the is very dim.....when i plug the old cracked 1 up it works fine....any suggestions?
If you see a dim image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
Mar 10, 2009 | Toshiba Satellite A105-S4074 Notebook PC
A105 LCD problem
I don't know where this thread was originated, but your laptop has only one inverter board.
The inverter is a small board that powers the AC lamp that provides backlight to LCD.
Here is the spare:
Toshiba LCD Inverter Board M110 A105 A100 ...
See here Toshiba Satellite A105. How to remove and replace laptop FL
Dec 29, 2008 | Toshiba Satellite A105 Notebook
Display shutdown
The next time this happens, try to manually operate the lid switch a couple of times. These switches can go bad and allow the unit to go into hibernation mode.
Feb 23, 2008 | Toshiba Satellite A105-S4074 Notebook
Toshiba Satellite A105 lcd display
keep typing the combination of "Fn" and "F7" on the keypad .
note: you can find "Fn" on the lower left of the keyboard and "F7" on the topmost right of the keyboard...
Please let me know the results...
Jan 09, 2008 | Toshiba Satellite A105 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
