SOURCE: Buzzing intermittent
could be a relay failing, a long 2 -3 seconds hard electrical hum could be the compressor failing & the relay overload is doing it's job shutting down your overheating compressor, unplug it for 30 min plug it back in a slight hum & click off is most likely just a relay but a long hard electrical hum is bad news Compressor & if it has no warranty left on the compressor repair could run $500.00- $700.00.
SOURCE: Amana ARB9059cs: compressor makes loud noise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
SOURCE: The ice maker in my Amana refrigerator is not
Good day,
You'll need to start from he beginning and follow thru. It should solve your problem. It is important that the feezer temperature is normal. Any temperature above 14 degrees will automatically lock out the ice maker, and even at 14 degrees the production would be pathetic. It should be between 0 an 5 degrees.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
SOURCE: new Amana refrigerator with high pitched whistling noise
We have summarised all possible problem for this case here to this link
http://www.fixya.com/support/r6008187-side_side_refrigerator_whistling_sound
SOURCE: Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
