Question about Motorola Mobility RAZR V3i Cellular Phone
Need help please
Hi. have mot v3i about 5 of them i have seen so far. if you put a battery it starts to get very hot and battery will go empty and phone will go off. could you help. i am a technician( beginer).
    Sergeant:
  • 452 Answers
Charge ur battery at least for 6 hrs.,if facing same problem then chnge ur battery .
Posted on Oct 20, 2007
SOURCE:
How to clean canon iX5000 print heads print nozzles etc ive got white lines appearing in the prints
Hi, Try first with cleaning tests on maintenance mode.Make sure all cartridges are not empty.If not help try manually cleaning.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head. Thank you for your time and best wishes for your effort.
Jan 06, 2011 | Canon PIXMA iP5000 InkJet Photo Printer
2002 cbr 1100 xx been sitting for 5 years just put new battery in & fresh gas now it is flooding fuel into crank case
Had the same problem with mine, been stood for 1 year. Put a new battery on it everything was fine passed the M.O.T. Waited until the end of the month to tax and it wouldn't start. Plenty of petrol in the tank, wouldn't crank over on the starter, but could hear the fuel pump kicking in. Looking for a fault and kept trying it, checked for loose wires and blown fuses to no avail. Then i noticed fuel light came on checking tank was empty. Wondering where the fuel had gone I found the engine had flooded into the crank. Stripped everything down found the problem was neutral switch was broke. Check this hope it helps you, mine in the 1999 fuel injected model. Cheers Kev :o)
Oct 08, 2010 | 2002 Honda CBR 1100 XX Super blackbird
O plz help me with motorola v3i charging
Run the phone till the battery dies, remove battery for at least 5 mins. Replace battery, charge overnight with phone turned off
Nov 26, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Instructions to clean print head of Canon iP5000 printer, please.
Nov 23, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Trying to download driver's for my Motorola RAZR v3i
If any of them have a free trial you can try that and then cancel. Some links below. Good luck. http://www.h4x3d.com/motorola-razr-v3i-software-usb-driver/
Aug 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Can u help me
You need to download software from Motorola site (which is not free) http://www.store.motorola.com/mot/en/US/adirect/motorola?cmd=catDisplayStyle&catKey=600960
There are of course many places on the web where you can get cracked versions for free but since that is illegal I'm not going to suggest that as a solution.
May 06, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Phone will not power on and battery is good
hi check under your battery if the sticker is white or pinkish
it sounds like a sort of water damage occured
if NOT, then its a board issue - it will be about 60-80$ to replace
Jan 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
V3i Problems
you need to have the flex cable replaced
Dec 30, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Help please
try changing its flex... its a common prob of v3 models...
Oct 13, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAZR V3i - Keypad blinks on regular interval. No display
reinsert the battery properly.or cahrge ur battery at least 6 hrs..
Aug 31, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
