Question about GPS
Shuts off itself
Shuts down and restarts by itself. it does hold the location i programmed in, but it takes several restarts till it works properly
Had the same problem. Downloaded program update. No more problem.
Posted on Nov 15, 2007
I had the same exact problem.  The solution had nothing to do with software.  Apparently the connection on the Speaker-slash-12Volt DC Power Supply cable went bad.  And apparently this is very common.  (The location of that bad connection is the place where the cable connects with the GPS, that plug that you slide sideways to supply power to the GPS when you drive. The solution... purchase a new cable.
https://buy.garmin.com/shop/shop.do?pID=1030
A friend helped me buy my original Garmin 2720 and he also immediately diagnosed the source of the problem when my power went out intermittently.  He ordered a new replacement cable and all has worked fine since then.  So this is NOT a software problem, it is a simple $40 accessory (hardware) problem. Just replace the cable with a new one.
Posted on Oct 15, 2007
What version of the firmware is loaded in your GPS? My 2720 was doing the same thing. It would reset itself every 2 or 3 minutes no matter what I did. I updated the firmware to the latest version from the Garmin web site (version 7.1 I think) and it works just fine now.
Posted on Oct 08, 2007
I have the same proble here in florida guess I will never buy another Garmin since I wasted 1100 dollars on the unit that keeps restarting every few minutes
Posted on Oct 07, 2007
  • shmoo Oct 15, 2007
    Finally got my problem fixed with the garmin 2720 restarting every few minutes I first thought it was the power cable so i wasted 50 bucks on that, then i found this site and read where if i updated my firmware it would work. Well it did except i lost my voice prompts which it tells you. you may after you update but all you do is click on where it tells you and download the voice again. So after that I tried it and it would only say the name of the place I was going I put in Walmart where I live and all it would say was Walmart. So after scratching my head for a few minutes while sitting in the car I went into the menu and reset the defaults and it worked but after that you got too set it back the way you want it as far as your personal preferances. hope this helps someone cause I was scratching my head trying too figure this out since I never abused my garmin and its never been dropped hope this helps...
October 6, 2007 Same problem in Florida. I have not used my 2720 in the last month, so I do not know when this could have actually started. I was beginning to think I had a defective unit, but I guess there is something else happening with Garmin? Would someone from Garmin respond to this problem??
Posted on Oct 06, 2007
  • doxy80 Oct 10, 2007
    A Great Big Thank You to the person that posted solution #3.
    The solution requires a software update that can be entirely done online.
    The software version that you will get updated to is 7.1.
    Thanks again to the Guest Post on Solution #3. It does work.
    get on www.garmin.com for the right fix.
    Doxy80
SAME THING . STARTED TODAY . UNIT SHUTS OFF BUT NOT COMPLETELY , GOES TO START UP SCREEN AND THEN BACK TO NAVIGATING . DOES THIS ABOUT EVERY 3 - 4 MINUTES
Posted on Sep 19, 2007
My 2720 just starting doing that today. used it fine for past 4 days on a trip, now it is acting up. Less than 1 year old
Posted on Sep 18, 2007
Trio pro 10.6 2 in 1 for windows. screen show working on updates-100% complete-don't turn off your computer. has been on screen for several hours...is frozen
In that case, you should probably just hold the power button in for a few seconds till the computer shuts down, restart and hope the update didn't mess up your system. If it did, you may have to use system restore or another option to repair the computer.
Apr 14, 2018 | Pro Computers & Internet
I have a gateway laptop LT4008u I need to know if anyone can please help me learn how to restore it back to factory settings.
If you still have the factory O.E.M. in the partition you should be able to do a shortcut key recovery, turn on the device while holding down "ALT" & tap tap tap the "F10" key, it take several attempts of a "hard shut down" & "restart" (power button), if your hardware is working & the device has the original factory O.S. it will bring up the "factory default reset" I've had to "shut down & start up" while pecking away at the keys 9 or 10 times on some devices till the reset finely pop up.. if that does not work try tapping "F8" on the start up, it should give you a few recovery options .. I wish you all the best..
May 30, 2015 | Gateway Lt4008u Atom N2600 Dualcore 1. Ghz...
Acer Aspire 7560 wont restart
Before shutting down your system click on any programs still running and shut them down. This will cut the time for normal shut down to take place.
You could also run a hard drive diagnostic to see if it has any errors. There might be some if you don't let the computer shut down itself. Restarting can also cause the programs to become corrupt, if they didn't shut down right. Running a defrag on the drive will also help it shut down quicker.
Look on the net also for information on getting your PC to shut down quicker.
Oct 18, 2014 | Acer Aspire Computers & Internet
Beyluxe deepfreeze
Deep freeze? Is your operating system froze or locked up? That could be several things, ram, a hidden program running in the background, malware or spyware. Have you shut the system down? Not a restart but a complete shut down.Then try restarting. If it won't shut down itself, push and hold the power button for 4 seconds until it' off. Wait about 3 or 4 seconds for the hard drive to stop, then restart.
Mar 25, 2014 | Computers & Internet
IPad shuts down itself
It seems that you've already tried reset (holding the home and power buttons, right?) the iPad and it does not work.
So you may need to connect your iPad to your computer and do a factory restore using iTunes.
Check this: http://support.apple.com/kb/HT1414
Jul 18, 2012 | Apple iPad 32 GB WiFi Tablet PC
AOL Broadband - no probs getting internet connection, can access through internet explorer. Mother wants to be able to access through AOL software...she prefers it! Had connection probs, so AOL provided...
Sounds like the router is not configured properly. I would follow the instructions that came with the router. There is a free program called Network Magic www.networkmagic.com that you can download and run free for 30 days. I have used this program to sortt out network related problems
Mar 19, 2011 | Computers & Internet
Laptop shuts itself off when trying to connect to the internet
if you have a dialogue box appearing with a countdown timer appearing saying windowshas encountered a problem and will shut down in blah blah seconds then you have a virus on your pc
to disable the shutdown (only if the above applies)
click start > control panel > administrator tools > services
when the services manager window opens scroll down the right window till you locate Remote Procedure Call (RPC) Locator
double click on it
click on recovery and change all three cdrop menus to take no action
then restart the pc
once restarted update your anti virus and do a complete scan of your pc
Feb 25, 2011 | Dell Precision M65 Notebook
How to reboot computer
hi
  • Decide what kind of reboot you are going to do. A soft reboot is performed the way you are “supposed” to do it. For a soft Windows reboot, go to the Start menu and select “Shut Down” or “Restart.” The computer will then shut itself down. Clicking “Restart” makes it boot up without further intervention from you.
  • Step 2 Perform a hard reboot by pushing the computer’s power button and holding it until the computer shuts down. Wait 45 seconds and restart the computer by pushing the power button again. You may have to start up in safe mode, but that also allows you the chance to restart properly or work on programs in a safer way. This method may cause you to lose data or mess up the operation of some of your programs. But it may be the only option if your computer's hard drive is frozen.
  • Step 3 Power down all of the computer's components. Shut off all of the peripherals you have attached to your computer, and disconnect the cables. Then, plug all of the peripherals back in, and restart your computer. This can often solve problems with your hard drive.
  • Step 4 Purchase and install a program such as Drive Reboot Restore PC 6.0 that streamlines the hard drive reboot process. These applications help prevent the problems that can develop after repeated computer use. They also ensure that your hard drive maintains the configuration you want each time you turn it on.
  • Step 5 Investigate what the problem may be with your hard drive. Because of its delicate nature, your hard drive can very easily be thrown off.
  • Jul 04, 2010 | Compaq Pavilion ZT3280US Notebook
    Restart
    Restart the computer and hold down the f11 key till you hear a bell.
    This will activate the system restore program.
    Select restore to factory settings/ default.
    That should help you out.
    Cheers.
    Apr 29, 2010 | Compaq Presario CQ60-220US PC Laptop
    Motorola h500
    This works. Once your phone IDs the headset hit the OK button (not select) and the rest is simple.
    Mar 04, 2007 | Motorola Mobility H500 Wireless Headset
    GPS Logo
    551 people viewed this question
    Top GPS Experts
    Marvin
    Marvin
    Andrew Taylor
    Andrew Taylor
    Are you a GPS Expert? Answer questions, earn points and help others
