Question about NTL D6000 Cordless Phone
NTL VS 3000 cordless phone
I got this phone and followed all the instructions. The handset LCD display worked fine, and the signal strength and battery were fine also. My problem is that I couldn't get a dialling tone and therefore was unable to either make or receive calls. I phoned the helpline and the advisor asked me to disconnect everything and remove the batteries from the handset and leave it for 1 hour. When I reconnected I still couldnt get a dialling tone. Phoned advisor again who says the unit is faulty. The person I bought it from (second hand) says it was ok when it left him. Any ideas what the problem might be? Many thanks.
5 Suggested Answers
SOURCE:
rizla
  • 1463 Answers
SOURCE: Help for the ntlD5000
hi
just seen this post a user guide can be obtained from here
NTL - Original
if still needed ?.
riz.
Posted on May 09, 2008
  • 15 Answers
SOURCE: NTL VS1003 Cordless Phone Problem
You should be able to download a copy of the manual at :
www.cordless-phones.uk.com
Hope you find the solution there!
Posted on Mar 01, 2009
SOURCE: No dialling tone - just a beeping sound
A bit late for a reply I realise, however I had a similar problem with the D5100 which may be resolved in the following way. For some inexplicable reason, something triggers a call bar for all outgoing calls on the D5100 handset... other handsets without the answerphone should be OK. To resolve, go to menu, select base - call bar , enter pin (should be either 4 or 8 zeros by default) and remove the call bar.
Posted on Apr 03, 2010
  • 179 Answers
SOURCE: i cant find my instruction manual for my ntl
Here is a link for a pdf download version of your manual.
I hope it helps? :)
http://www.cordless-phones.uk.com/userguide/vs2000.pdf
Posted on Jul 16, 2010
Battery doesn't charge
Shirley, check if you inserted the chip properly. Usually the bars are your wifi strength. Most likely its the chip.
Mar 02, 2014 | Panasonic Lands Phones
NTL VS205 lost manual
Lets see if I can get my hands on a manual. one moment
Jun 27, 2008 | NTL D6000 Cordless Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
LCD dispaly is distorted
you either need a new battery or some one droped the phone
Feb 11, 2009 | Uniden DECT 6.0 Cordless Telephone...
Display on phone just started showing all info backwards
This issue is more like hardware issue. LCD cable cold solder, mabye need to open the handset ,the check if the LCD cable connection is ok or not.
Jan 21, 2009 | Uniden Cordless Phone
Sep 01, 2008 | NTL VS1500 Cordless Phone
Ntl vs2000
You can download a copy of the User Manual at:
Hope this solves the problem!
Jul 15, 2008 | NTL VS1500 Cordless Phone
NTL VS2000 cordless phone
Here's a link to a manual that includes the VS2000 handset.
http://www.telephones4u.co.uk/userguides/VS2003.pdf
Hope you find a solution.
Jun 30, 2008 | Lands Phones
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Cordless Handset fails to Link to main corded phone
Here it is, 2008, March and still no answer! LOL! I am having the same problem! It linked fine when I first got it, and now since I can't find the manual I can't get it to link again! Can anyone help? Please
Apr 13, 2007 | GE 27957GE1 Phone
NTL D6000 Cordless Phone Logo
63 people viewed this question
Top NTL Lands Phones Experts
Ekse
ray gallant
ray gallant
suresh Kulkarni
suresh Kulkarni
Are you a NTL Lands Phone Expert? Answer questions, earn points and help others
