Question about Bosch Exxcel WVT 2850 Front Load Washer / Dryer
Washing machine is not completing cycle
I am getting an error message E06 from the Bosch Exxcel. E-nr:vwt2850GB/02 FD:8411 I have drained the pump and little black hose from the bottom of the panel twice. After the first attempt it successfully did a complete drain and spin for 15 minutes with no problems. But then again, there was no water to drain. I thought all was fixed (hoped) and started a new wash, but it got half way through and stopped again. I did lose a bra wire, which I heard struggling around my drum but I thought it had worked its way free. I can't find it poking out of the drum. I am assuming that it was this that has caused the major problem and not the 50p and 2p I found on the first attemp at the clean out of the pump. Is it time for a specialist to visit? Please advise.
Had the same thing. Managed to sort it out by checking a few things and getting my hands dirty.
First things first: Remove the rectangular fascia at the bottom front of the machine - on my model you only need a coin to turn the two plastic screws. Unclip the black rubber drain pipe, remove the plug from the end and drain the water into a bowl (or several bowls).
Then undo the round plug at the bottom left of the machine (more water will come out) which will give you access to the extractor pump. Check that there are no obstructions in there and that the small propeller in there can turn freely.
If there is no obstruction there then we move onto the next steps.
If you can figure out how to remove the front of the machine then you will find this part easier - I couldn't so I ended up reaching in from the back.
First, TURN OFF THE POWER. Then, on the front of the machine, on the bottom left, undo the screws that fasten the extractor pump onto the front of the machine. Then pull the machine out from the wall so that you can get to the back of it. Remove the back of the machine by taking out the ten or so screws.
Looking in from the back: At the bottom-front-right of the machine you will see the extractor pump. It will have two hoses attached to it - a fat one and a slightly thinner one. Reach into the bottom of the machine and remove the power plug from the back of the extractor pump. Then, using a pair of pliers (or something similar) to open the spring clip, remove the thinner of the two hoses (the drain hose) from the pump unit. This can be fiddly - especially if you're doing it from the back of the machine.
Pull the hose out of the machine and check it for obstructions. If there are no obstructions in there then move onto the next step.
Reach back into the machine and, again using the pliers, remove the fatter tube from the pump. Remove the pump from the machine and check it for obstructions in the entry and exit holes, and also make sure that the propeller isn't obstructed. Then shake and squeeze the fatter tube to see if there is an obstruction in there (I had about five quids worth of change stuck in there which was where my issue was located).
If you've found no obstruction by now I'm afraid that I'm stumped :-(
Best of luck.
Posted on Aug 19, 2009
    Scholar:
  • 146 Answers
Remove the hose that goes from the drum to the drain pump and you may find the bra wire jamming the pump. Switch off and unplug machine first.
Posted on Oct 31, 2007
Classixx 1000 Express. Washes. Stops. Spin light blinks. Nothing else. What's wrong?
Sounds like the switch to let it know it's not off center is broken
Apr 12, 2016 | Bosch Washing Machines
What does E18 fault code mean on a Bosch exxcel 8 washing machine mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Washing Machines
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after....
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Bosch Washing Machines
Bosch exxcel f01 code comes up after switching on
Question?#$@???
Exxcel 1400 express with the number E-Nr. WFX2867GB/10 FD 8410604749,
The last time I used the machine I interrupted it while it was washing and thereafter its stopped working. When turned on it will collect water and detergent but will not turn or wash.
What do I do????
Jul 16, 2011 | Washing Machines
I have got a Bosch Exxcel WAE 244 64GB?03 FD Washer. I have noticed, that duricng the cicle, it can be on a cotton wash 42 min before the end or 12 min before the end, that while not rotating the maccchine...
Hi ritarorschac,
I believe you have something obstructing the Drain Pump Impeller.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter:
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Bosch Exxcel WFO 2865 Front Load Washer
Error message E20 and can't open the machine
E-20 error is for drain pump /filter blockage.
Drain the pump manually.Clean it internally.The filter and drain pump are getting blocked in your machine.It needs to be cleaned.In some cases drain pump needs to be replaced if its cracked.
This will help.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 11, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
  1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
  2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
Mar 01, 2009 | Bosch Washing Machines
Bosch Exxcel WVT 2850 Front Load Washer / Dryer Logo
1,105 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
