My Flip camera (mad by Pure Digital Technologies) has suddenly chosen to assign a date in 2016 to my video recordings. The last date that was correctly assigned was March 24, 2009. After that, it assigned a date of June 18, 2016 to the next video that I recorded. It now continues to assign dates in 2016
How can I set the date to today's date?
Thanks,
Hadi
SOURCE: lost time/inaccessible files on flip
Have you tried this? (From the Flip website Help section)
We suggest trying the following to regain your full record time.
Connect your camcorder to your computer and open your DCIM/100VIDEO folder. This folder contains the videos from your Flip Video camcorder. When your videos are manually renamed within this folder, they are no longer recognized by the Flip Video program. Please ensure that all videos in this folder are carrying their original name. For example, VID#####.AVI where ##### is any number between 00001 and 99998. Then, delete all videos you have previously saved from this folder. Your videos cannot be retrieved once they are deleted, so please make sure you have the videos you wish to keep saved into another folder before doing this.
Also make sure you have deleted any videos that reside outside of the DCIM/100VIDEO folder within your camcorder's root directory.
After you have deleted all videos, disconnect your camcorder and check on your record time. If you have still not regained your full record time, please reconnect your camcorder and empty your "trash can". Then, power your camcorder on and off 8 times.
This may sound risky, but I did this and my Camera is working perfectly again... If you don't have any videos on it you need to salvage too badly this should do the trick.
1) Plug it in (obviously)
2) Go to My Computer and right click your video camera
3) Click Format
4) I clicked restore device defaults because it sounded safe (but may not be necessary)
5) Click start and begin the reformatting
After this i went from my incorrect 27:11 min. remaining on the camera to the full 60. Still records perfectly and the software is still on it and works correctly. Hope it helps some of you out there =)
SOURCE: Can not see the videos in the Flip Share window
Connect your flip video camcorder to your computer via the usb arm. you will find your video files in FLIPVIDEO(F:)->DCIM folder. Just copy your videos to your computer.
SOURCE: Flip Video Mino keeps freezing up, can't shut down or upload
At least the following works on my first generation Flip Ultra camcorder (not Mino). Remove battery, put it back next morning. After that be careful not to touch "on" slider switch on the side of the camcorder while Flip logo is still on the screen. I mean turn the device on by using the slider switch and do not touch that switch again until Flip logo on the screen is gone. Doing the opposite (trying to use the "on" switch again while device is still "booting" and Flip logo is on the screen) will lead to the Flip Ultra freeze.
SOURCE: Record Beep Tone - How To Shut Off
On the Mino HD, Hold down the record button as you turn the camera on. Navigate the menu and turn off the sound under the sound option.
My dates are all messed up to i dont know how to fix it
