Question about Oster 5838 ExpressBake Bread Maker
Oster 5821 breadmaker
The paddle that is in bread pand turns very hard. I can barely turn it by hand. Any solutions?
  • mousyrose Dec 04, 2007
    Yes the paddle in my Oster 5821 breadmaker is frozen. It won't turn. How do I get the old one out? I see online where I can purchase a new paddle.
    Thank you,
  • Anonymous Jan 07, 2009
    how do you take apart the lower end?
I had a paddle freeze on me too I took apart the lower end and lubricated it then put it back together
Posted on Apr 08, 2008
Bread crust burns even on "Light" setting
Contact Oster for advice. Here is their contact info-
Jul 28, 2015 | Oster 2 Lbs. Deluxe Bread & Dough Maker...
Oster 5821 Bread Maker: Paddle froze up, does not move
That shaft fits into a sealed bearing that is riveted to the bottom of the pan. When that seal freezes there is no way to free it up. The lubrication in the sealed bearing gets hard, especially if it's not used much..You may try putting hot water in the pan and soaking it but other than that the pan will need replacement. Sorry...Hank
Jul 10, 2010 | Oster Kitchen Appliances - Others
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
May 18, 2010 | Oster 5838 ExpressBake Bread Maker
The axis in the bottom of the pan, which holds the paddle, won't turn. The axis in bottom of the machine does seem to rotate when I try it without the pan. Is there a way to fix the pan?
Try putting warm water in the pan and let it soak. Try it a few times. If you can't turn the paddle by hand, then the sealed bearing that turns the paddle is frozen and can't be repaired. Sorry Hank
Feb 16, 2010 | Oster 5834 ExpressBake Bread Maker
Do you have available the User Manual/Recipe Book for Oster Bread Machine? Thanks. - -
Jul 06, 2009 | Oster Kitchen Appliances - Others
I need a copy of the Owner's Manual for Oster Bread Maker Mod. 5821
If manufacturer site is of no help, check here, they have the Sunbeam 5821 manual for download. This is the right manual!
May 15, 2009 | Oster 5838 ExpressBake Bread Maker
Paddle won't turn
Although my Oster breadmaker is older (5811) it had the same problem (frozen paddle) and I just fixed it today. First read this article on maintenance:, then watch this video on disassembling a breadmaker: The good news is the bottom comes more easily than the video and the workings are easier. If your belt is fine (which mine was since Oster is grooved differently than the video) then First turn the big wheel by hand a few times to "unlock" it's stiffness. Then remove the big wheel and belt. Oil both of the spindles with MACHINE OIL ONLY (like the first article emphasizes)--I used sewing machine oil. Mind you, I did this with my machine upside down to be sure oil ran down the shafts. Then re-assemble. This was a BBBBitch to do until I discovered the spindle on the big wheel is shaped like an elongated D. Once you figure that out, it will drop down easily. I stretched the tight belt back on by fitting it first into the smaller paddle end (to be sure the grooves are in place) then putting it around the big wheel, holding loose part with thumb and turning the wheel until it fell into place--sort of like a tire machine. (see attached picture) Now give it a few more spins by hand (it should spin freely) and replace bottom of machine. Voila. Mine is working perfectly now, and I hope yours will too.
Feb 10, 2009 | Oster 5834 ExpressBake Bread Maker
Oster breadmaker
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Nov 25, 2007 | Oster 5838 ExpressBake Bread Maker
Oster 5838 ExpressBake Bread Maker Logo
482 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
