How do I dissasemble and replace it?
How can I get the firing pin out of a Dan Wesson 357 ctg. Magazine
If you are referring to the pin on the AC brick (the part that actually plugs into the wall), then you don't fix it. Due to risk of fire, it would need to be replaced.
If the pin is on the laptop itself, then you would either need to replace the motherboard or obtain a DC jack and sodder it to the motherboard after removing the old one. (Generally, the DC jacks are not field replacable.)
Broken heater lamp error
The temperature won't rise by 1°C/33.8 °F during warming up and the heater is turned on for 5 seconds.
The temperature won't rise by 1°C/33.8 °F during printing and the heater is turned on for 5 seconds with the duty cycle more than 60%.
1. Defective fuser thermistor.
2. Broken thermal cutout or heater lamp.
3. Defective engine/high voltage PWB.
Turn power switch off, and remove power cord.
Detach YC7 connector on the engine/high voltage PWB.
Measure resistance between pins 1 and 2 of the detached connector.
Open (infinite)?
Yes Then - Replace the fuser thermistor.
No Then - Detach YC1 connector on the power source PWB.
- Measure resistance between pins 1 and 2 of the detached connector.
Open (infinite)?
Yes - Replace the thermal cutout or heater lamp.
No - Replace the engine/high voltage PWB.
I hope this was helpful,
Shawn
