I installed this XFX 750aSLI nForce motherboard and it works ok with the built in graphics but when I looked in the manual for instructions on installing a graphics card;I discovered their english is as bad as my chinese.I want to install a BFG Nvidia GeForce 9600 GT OC graphics card. Note:Operateing System=Vista Ultimate,PSU=750wat.Pwr.&Cool Slincer, Hard Dr.=Western Digital 120gb, Memory=Centon 4GB DDR2 kit 800 x2
Comments:
Apr 07, 2009
- Found that GPU was in wrong slot XFX instructions are very poor.
You will have to access the BIOS and disable the onboard graphics from there. Before you install your new card, boot the computer. As it is performing the POST, enter the BIOS (usually delete or F2 gets you in.) Once you have disabled the on board graphics, save your settings and exit. Then install your new card and attempt to boot the computer. If it will not boot, locate the CMOS jumper and activate it to reset back to default settings.
Comments:
Apr 07, 2009
- Glad you found your mistake. Drop by and rate the solution properly when you can, should be a helpful since my advice was correct from the symptoms you described.
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
