Question about Protron PLTV-32 Television
No sound with hdmi source
I have a problem with the sound on my Protron TV. The sound works fine on source av3. When I switch to source HDMI there is no sound. I have a HI-def dvr. Can you help me please. Thanks
Ours would'nt work either we unplug it and turned back on and it worked
Posted on Sep 10, 2007
SOURCE:
TV box is not working wend Is connected to HDMI switch.
CONNECT IT AGAIN TO HDMI INPUT AND CHANGE SOURCE ON THE TV SETTINGS INPUT SHOULD BE HDMI1
Jan 31, 2014 | AUVIO 4-In/1-Out HDMI Selector Switch with...
HDMI connection
A downloadable copy of the manual for a Protron PLTV-4250 is available here.
I went through it to check up on your concern. It was mention in page 34.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Protron > PLTV-4250
Feb 13, 2008 | Protron PLTV-4250 42 in. LCD Television
I have a Samsung HL-S5687WX/XAA and the screen is completely white and there is now sound on AV1. If we plug in our WII and go to Netflix on AV3 the picture and sound are fine. The HDMI source gives...
you either have incorrect placed or bad avi cable lastly could be a dmaged main board in the TV since other connections such as hdmi work fine focus on the avi device your connecting and test it o another tv with the current cables i bet it is not the TV
Mar 07, 2018 | Samsung HL-S5686W 56" HDTV
LD4088 LCD will not play sound via HDMI cables. Component cables are fine. Hear a faint "click" from speaker when switching to HDMI input. Have tried all three HDMI connectors and have tried...
This is how AUDIO works in HDMI setup, you can select the source to send the digital audio along with the digital video through HDMI, the receiving end HDMI sound setup must be set to receive the digital audio through HDMI. Otherwise the audio may be sent and received through analog audio ports (Red (Right channel) and White (Left channel) RCA jacks) in stead. Most of the new TV and DVD player use auto detection.
So please check the HDMI audio setup to see how the audio signals are set to be processed.
Please leave rating if it helps.
Jan 14, 2011 | Apex Digital LD4088 LCD TV
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
LG 37LC2D HDMI no signal (picture or sound) + crackling on audio
i have the same problem. i think they just get old, i solved the audio problem by taking the cove off the back and disconnecting the speakers, i now just use PC speakers, works grand. i haven't solved the HDMI problem yet..
Apr 29, 2010 | LG 37LC2D Television
Does this tv set have a reset button
are you using HDMI? because if you are using HDMI you may have im not sure what you call it but its 1080P 1080i 720p 720i etc. you might have a channel that is on 1080p but your tv might only support 720P or so on but if thats not the problem its some type of hardware issue sorry if this dosint help.
Jun 27, 2009 | Philips 55PW9363 55" Rear Projection...
Protron PLTV-32 Television Logo
277 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
