Question about Dell Inspiron 6400 Notebook
DELL 6400 pc card slot issue
I have a new 6400 with Vista and I am trying to use a scansisk 6-1 card adapter and the card slot does not even recognize that I have inserted the card. Any ideas. I tried to find out if the reader is vista compatible and I can not find anywhere that says it is not compatible. Any help would be welcomed. mark
    President:
  • 2,961 Answers
Check in device manager via control panel, then click classic view; that the pcmcia card bus controller is present in the list and install the card reader driver if one was supplied, if not then there is no need for a driver and it must be a fault with the pcmcia driver.
Posted on Sep 04, 2007
I have a dell inspiron 6400 and got a code 31 which i tried to update but it did not resolve the problem so I uninstalled microsoft 6 to 4 adaptor #29 and now don't know where or how to find and r
if your net is working than go for online updates...or the last option is to format and reinstall vista ...give me points if answer is sufficient..
Dec 29, 2012 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 wont recognize new battery
Well often batteries from 3rd party manufacturer do not work in some laptops, see even the batteries have a "Chip" in them identifying them. Also sometimes these batteries are just no-good. or arrive flat, too flat to be charged up via the supplied charger. Anyway hopefully none of that applies and this will work. Now Turn PC OFF, put battery in unit. Now plug in wall unit, then plug into the PC, now leave the PC totally alone for at least 3 hours. Now the unit should work. Now how we tell where the problem lies is like this, Turn OFF, take out battery, now plug in the wall adapter, now the PC should work Fine like this. Now remove wall adapter, and insert the battery, the unit should go on this.. ONLY of course if charged. Now if when plugged in there are problems, it is more than likely, that indeed the battery is faulty, in some way.
These links below detail what steps to take to remedy any situation. The 2nd link is great.
http://www.dell.com/content/topics/global.aspx/batteries_sitelet/en/batteries_faq?c=us&l=en&cs=04
http://ftp1.us.dell.com/diags/R66243.htm
Mar 22, 2010 | Dell Inspiron 6400 Notebook
Have a Dell Dimension 4600C Desktop. It no longer recognizes the ethernet cord when it is pulled in. The cords are fine. Even tried new ones. Think that the network adapter connector on the computer is bad...
More than likely it is your ethernet card that is bad. It will be easier to buy an ethernet card and install. The procedure is not hard. You will need to open your computer and sit the card in one of the open slots toward the back of the computer.
Mar 02, 2010 | Dell Dimension 4600 PC Desktop
Computer won't accept a compatible replacement battery for Dell Inspiron 6400
This could be due to a defective battery even though it is new. These batteries are what are called smart batteries. They have circuit boards mounted inside the battery pack that aids the computer in recognizing the battery as well as sending functional information to sensors in the laptop about battery health and performance. Try re-installing the old battery and see if it recognizes the old battery. if it does, the contact the company you purchased the battery from and let them know the problem. If the computer does not recognize the old battery anymore, there may be a problem with the charging circuit on the motherboard or the power adapter on the motherboard.
Jan 07, 2010 | Dell Inspiron 6400 Notebook
Network adapter not being recognized by pc
you need to disable the old network card go to the computer setting (CMOS) and disqble the network card (you are having a hardware addressing conflict.
Jul 01, 2009 | Computers & Internet
I Have a Dell Inspiron 6400 with Vista and It seems I am getting a memory or motherboard issue as the Caps and scroll lock LED's flash when I switch on and hold the FN key. Basically the laptop is not...
Getting the motherboard fixed may not be a cost effective solution.
You can salvage some of the components to use eg. the RAM and the hard disk.
Put the hard disk into an USB hard drive adapter case and use it as an external USB hard drive for backups etc.
Jun 25, 2009 | Dell Inspiron 6400 Notebook
Type II PC Card Slot does not work
Probably the drivers are missing. Go to Start, Control Panel,Syatem, Hardware, Device Manager. There should be a line that says PCMCIA adapters. If it has a red or yellow check mark then the drivers are faulty. If it's not there the drivers are missing. Download a new set of drivers from support.dell.com.
Apr 02, 2009 | Dell Latitude D620 Notebook
Dell Inspiron 6400 Vista CD Drive Does Not Recognize CDs
Try to use dvd cleaner disk to clean the lens, if it doesnot work, i think you have to replace your drive , this happens with Dell alot. but try to clean it, uninstall then install the driver back and check if its work.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 14, 2009 | Dell Inspiron 6400 Notebook
Driver or Hardware issue
This could be a problem with the external attachment, but it sounds more like a compatiblilty issue with Vista. Check the compatibility of the devices and their drivers, and get back to me.
Jul 31, 2008 | Dell Inspiron 1501 Notebook
Verizon Wireless Card not working with Dell
contact dell and let them know there is a hardware issue with this card they may have a driver work around
Apr 07, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 6400 Notebook Logo
140 people viewed this question
Clive
Clive
Alun Cox
