When I press cook or convect the display comes on but the oven won't heat. The grill is working ok and the stove top also. It happened after a big spill. I was told it's a problem with the control panel, what do you think?
Before you replace the control panel, take a quick look inside the oven at the ceramic spark starter.. when you (tyr to) turn your oven on you should hear a bunch of little snap sounds.. sparks trying to light the burners inside the oven..
if you try to use the element (broil) without the gas - you'll get a better bearing on whether or not the gas element(s) are lighting or not inside the oven..
hope that helps..
