SOURCE: where do you plug in the trailer brake controler harness
Brake controller should plug into the rear lights.
SOURCE: Will a 1984 350 cu short block fit a 1993 GMC
The heads are different but the lower end should be just fine.
SOURCE: where do i find a knock sensor a 1993 gmc sierra
Should be on the right side of the engine by the starter.Has a 1 wire connector.It does not go into the cooling system so you can just take it out without draining the coolant.Hope this helps.Good luck.
