The power works, the voltages are all correct, the monitor works, but nothing shows up on the screen. Also, the hard-drive light stays on.
Unit unplugged to outlet and power off.Check RAM. Reseat or clean its edge connector using soft eraser before reseating.
Or it is not receiving enough power if you are using small AVR.You can try to plug it directly into the power outlet if its voltage requirements is the same with the unit.
First of all, power down, remove all cables and check to see if your Graphics card is inserted correctly. Also try removing and re-seating the graphics card.
Check the cable from graphics card to monitor. Also try cable and monitor on another pc to eliminate this possible cause.
Failing that, you could have a BIOS problem.....did you recently try to flash your BIOS chip??
Shine a flashlight on the dark screen to see if you barely
see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If so that proves your
video card is ok. The video will show on most systems when you reboot
without you having to do anything. Some systems will require you to hit the FN
(Function key) + F1 thru F12. Hold down the FN key then hit the correct
key for displaying on the monitor (F1 thru F12). The correct key will
normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
bad.
