Question about Sony PlayStation Portable (PSP) Console
My psp turns on and then turn off by itself
When i turn on my psp it says SONY COMPUTER ERNTERTAINMENT (with the little music)..... Then 3 seconds later the psp atomaticly turn off. Ive discovered that if i turn on the psp and turn on the HOLD switch the psp stays on, but i cant do anyting with it because its on HOLD. I take it out of HOLD and it turns off again.... I have tried charging my psp, and checked the battery, but not results.... CAN ANYONE HELP???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
There is a dry solder (loose connection) internally ON/OFF PC Board of your PSP. you have to open the PSP and resolder the contacts of ON/OFF switch.
Posted on Sep 04, 2007
  • annaflo_213 Apr 11, 2011
    are you sure this is the best solution....try to make a video to prove your solution :D
How to pu music on psp
Ok its a little bit of a long method but it can be done.
Step 1. Connect your PSP to your computer using a USB cable.
Step 2. Goto Settings and find the setting thats says "USB Connection"
Step 3. Your PSP will now connect to your computer. Now on your computer goto Start -> Computer. Your PSP will probably be listed as E:
Step 4. Double click on your PSP drive (probably E:)
Step 5. If you are using Vista click Organize from the menu bar of the drive windows that opens and then click New Folder. If you are using XP just right click in the drive window and select new folder.
Step 6. A little box with the folder name "New Folder" will appear highlighted in blue. Call the folder "Music"
Step 7. Next all you need to do is drag and drop your music files (which mjust be MP3) into this music folder from your computer.
Step 8. When you are done press "O" on the PSP and it will end the USB connection.
Step 9. Goto the Music option on your PSP and scroll down to memory stick and then into your music folder. All your music should now be there.
Hope this helps
Jul 30, 2010 | Sony PlayStation Portable (PSP) Console
How do I download music onto my Psp 300?
Please try the following:
  1. Step 1 First, add connect your PSP with your computer using your USB, but you have to go to "settings" and click on "USB connection"
  2. Step 2 When your PSP is connected to your computer, a hard drive will appear [for example: hard drive (F:)]. That hard drive is for your PSP
  3. Step 3 Click on that hard drive and make a folder called "music"
  4. Step 4 Finally, open your folder full of musics and drag musics you like in the the "music" folder
  5. Step 5 Finally, when you disconnect your PSP with your computer, go to "Music" on your PSP and listen to your favorite songs!
Hope it helped.
Nov 22, 2009 | Sony PSP-3000 Black Console
How to add music to your PSP
You will need to plug the psp into your computer,
Then selected usb mode
Wait a few minutes until the computer recognizes the device.
Go to your desktop and open "My Computer" and look for your PSP.
You will need to create a new folder called music and then you can just drag and drop your music files.
If that sound a little to difficult there is a freeware application that will put music on it for you. http://www.download.com/PSP-Shuffle/3000-2248_4-10407187.html?tag=lst-0-2
Good Luck!
Nov 20, 2009 | Sony Video Game Consoles & Games
Psp will not download r rated movie i turned off
You can alternative download this r rated movies on your computer and transfer to your psp via usb or memory stick. This should be a way out the other way. Hope this helped.
Regards
Nov 08, 2009 | Sony PlayStation Portable (PSP) Console
My psp freezes then turns off 15+ seconds later wat is happening?
same thing happend to me, music works fine i think, but when playing games it just frezzes after a little bit... maybe an scratch umd?
Aug 12, 2009 | Sony PlayStation Portable (PSP) Console
Wants to put games, songs and videos on my psp
If you want to put games, music and videos on your psp, just follow some steps and requirements:
Requirements:
+USB Cable compatible for psp
+Computer
+And Of course, your psp
GAMES:
step 1: connect your psp from usb to computer
step 2: turn on your psp, and go to settings, then go to USB Connection
step 3: while you connect your psp to your pc then wait... an autoplay window suddenly appears.
step 4: click the "view files"
step 5: then a window appears that should be your psp's files
the:
PSP MUSIC VIDEO MP_ROOT PICTURES
ISO(if you don't have a ISO folder, create one, type the folder name ISO, it should be all caps)
step 6: Go to ISO folder...
step 7: just copy and paste some games that you like or drag them or drop to ISO folder
MUSIC:
step 1: Follow the steps from GAME to step 1 to 4
step 2: copy and paste the to your psp(the format of the songs should be mp3 or mp4)
step 3: then, you can play them
VIDEOS:
step 1: follow the steps from the music...
(it should be m-peg 4 format of the videos)
thats all!...
Jan 03, 2009 | Sony PlayStation Portable (PSP) Console
Sony psp problem
Remove the battery for 15 minutes, connect the AC Adapter and install the battery again.
It that doesn't work, remove the battery again, wait 15 minutes, install it and plug the AC Adapter.
It's a weird problem but in my PSP i get around that way.
Feb 07, 2008 | Sony PlayStation Portable (PSP) Console
Usb cable
Just like sorta of add-on to szwaan's answer:
You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
Dec 21, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
295 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
