Question about Sanyo DS25390 TV
Tv won't turn on
I have a 36" sanyo DS31650. TV worked fine for the last 4 years.I went to turn it on one morning and I had nothing. It will not come on with the remote or by pushing the power button,any suggestions would be appreciated. thank you
  • TomGray Feb 06, 2008
    I have exactly the same problem on my DS31650 (and of course it's plugged in). Sanyo customer support suggest that it might be a blown fuse, but I don't know how to identify it among all the other stuff that's inside the unit.
  • cgregg01 Jun 10, 2008
    I'm having exactly the same problem with my Sanyo DS31650. My son went to turn it on, nothing happened. Tried using the remote, same thing. All plugs are in place, nothing has been changed. Just won't come on. I'm also assuming it's a fuse, but how to find and replace it? Don't want to pay repair costs for more than a new TV would cost, but this is my main tv so want to fix it ASAP. Anyone with help or info would be greatly appreciated!! Also, I'm in the northeast Florida area, and if you know of a reputable repair service in the Duval, Clay, St. John's County area, I'd love to get their info!
Plug it in.
Posted on Sep 03, 2007
SOURCE:
My TV won't turn on. I have a 42" Sanyo LCD TV. We
You have a back light issue. Sometimes it's cheaper to get another one. Tcon board failure most likely. If you can find a rv repair or electronics repair they might do the work but as you got 5 years from it. Most TV sets fail in less time than that.
Jul 20, 2017 | Televison & Video
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
It won't start. Could it be the lamp?
I have a 36" Panasonic TV (manufactured in 2004) that suddenly stopped working. It was working fine up until I turned it off one evening before going to bed. The next morning, when I went to turn it on, NOTHING. No power indicator light, NOTHING. I'm a big "do-it-yourselfer", so I took off the back cover of the TV case and discovered that it was just a burnt-out fuse. It is a small "snap-in" glass fuse that should be mounted to a circuit board near the area where the main power chord enters the back of the TV. I found the replacement fuses at Radio Shack. The fuse came in a package of 4, for $2.99. Cheap fix and works great! The biggest problem I had with the fix is that the TV weighs 386 lbs., so I had to get help lifting it out and back into the entertainment center.
BK
Dec 08, 2010 | Panasonic Televison & Video
50 inch Sanyo Vizon Plasma TV. Has sound but no picture for last few days. 2 years old
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Sep 06, 2009 | Sanyo Televison & Video
No power. No lights.
I have the exact same problem.
TV was working fine (if you call having to deal with blinking lights of death and multiple starrt up errors...) - but I powered through it all.
This TV is 6 years old and started acting up after the 4-year extended warranty ran out.
This morning I went to turn it on and nothing.
Hmmm... Got my manual to count the blinking light code...
Whoops. No lights. Nothing. Checked plug. Checked power.
Uninstalled and installed lamp. Checked plug and power again.
Nothing.
Not one stinking light. No power to fan. Nothing.
How does a TV just DIE???
Mar 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
GE television 32GT740 Guideplus Gemstar
6/1/2010 11:34:21 AM
Good morning I have sound problem it started with the cable hook up there box to the television, now sound is very low. Turn up the TV control to max, nothing but low sound. Of course cable people have no idea of a problem, I disconnected the cable but the same problem, love the set work for two years, note: thing happen when all analog change to digital. help!
Dec 12, 2008 | GE 32GT740 32" TV
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
TV won't turn on
Unless you know Solid State Electronics, there is nothing you can do. At best, You could unplug the TV, remove the back cover, slide out the Circuit board, and check the fuses. They will be at the front of the Circuit board, left hand side. But in all likelihood, it is not just the fuses, the Power Regulator STR would also be short circuited (happens often in SONY TVs) and so it is best that a professional technician have a look.
Sep 26, 2006 | Sony KV-36FS17 36" TV
Televison & Video Logo
273 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
