Question about LG WM-1480FHD Front Load Washer
LG 1480fhd can not open front door tried child lock on off spin rinse new wash door will not release is there any way of opening the door.
In my case this problem was caused by a broken handle in the door assembly. I agree with dovi that you can release the catch from inside the machine if you remove the soap dispenser unit. You can then remove the door and disassemble it to see if the plastic trigger is broken.
If the door handle is broken you cannot exert any force on the metal catch - you think you are triggering the mechanism but you are not.
Posted on Nov 17, 2007
  • 641 Answers
Try first to unplug the power cable and see if it allow you to open the door. In case it will not help, you have to raise the top of the washer to get to the switch and release it manually (The switch is inside the washing machine main housing near the door frame). Good luck
Posted on Sep 03, 2007
SOURCE:
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
How to release child lock in seimens washing machine that is wash and dry D12-52 1200 rpm
Child lock will deactivate only in the original programme that it was activated in. If you have forgotten the orginal programme, try deactivating separately in each programme.
To deactivate child lock press the clock key for 5 seconds.
Nov 07, 2010 | Siemens WFXD8400UC Front Load Washer
Lg intellowasher model wm 1290fhb door will not open. tried waiting 1 hour! tried power on and off, tried child lock
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while pressing the SPIN SPEED and SOIL LEVEL buttons. Then buzzer will sound twice.
  3. Press the Start/Pause button repeatedly with about 1 second interval until the lamps goes out.
  4. The washer powers off and unlock the door.
Oct 18, 2009 | LG WM-1290FHB Front Load Washer
I can not open my front loader door i think it has the child proof lock on iit is a LG
THE MACHINE HAS A PROBLEM WITH THE AUTOMATIC DOOR RELEASE THAT SHOULD UNLATCH THE DOOR AT THE END OF THE WASH CYCLE, THIS LATCH SOLENOID MAY BE DEFECTIVE OR STUCK
Sep 29, 2009 | Washing Machines
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Washing machine - LG TROMM - door is not opening
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............I'll be back with a further post
Mar 30, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washing machine does'nt start
Had that problem before. CL means child lock. You need to press the wash and rinse buttons together to unlock.
Mar 23, 2008 | LG WM-1480FHD Front Load Washer
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Faulty door catch on my LG washer?
I have had the same problem for a week now. Until I find a spare part I slide a scraper to push the catch open. That just works.
Dec 05, 2007 | LG WM-1480FHD Front Load Washer
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Aug 26, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM-1480FHD Front Load Washer Logo
400 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
