Question about Dual XD-7500 CD Player
NO Power Installed Unit and everything worked, radio was fine, the CD worked fine, then after about one day of use, i put in a CD and everything shutdown ?? looked liked I blew the fuse, but fuse was fine, all power to the unit is fine...but now I have a stuck CD inside as the Power button or the CD button or the Reset button do nothing ??? I think its junk.
  • 98 Answers
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key one. If only one has power the radio will not work. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Posted on Sep 05, 2007
Have a cadi cts 03 and my radio display when out cd still works and I check all fuses and there fine what could it be?
If the cd still works then it is just a bad display in the unit , replacing the unit would be cheaper than repairing it.
Nov 02, 2014 | Cadillac CTS Cars & Trucks
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
Radio won't power up
Check the power wire to radio. and check the fuse for radio also. If ok, The radio may have gotten moisture etc, from sitting for 2 years. Good-Day!
Aug 21, 2014 | Cars & Trucks
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
I have a 2006 HHR and I've installed an
Check the accessory wire (red) connection that you used. Make sure that the connection is secure. Jiggle the wires at each junction and see if this causes your problem to present itself. If it doesn't consistently happen when you jiggle the accessory wire, the connection isn't the problem. It's possible you have an internal issue with your radio that you cannot repair yourself. Your CD will still eject because that operates on the memory wire (normally yellow coming from the back of your radio). That wire always has power whether your car or the radio is turned on or not.
Nov 15, 2017 | Car Audio & Video
Radio won't work on my Dual XD1222
same problem, but if i disconnect unit or car battery systems (resets?) works again for a day or two then problem comes back
Feb 05, 2010 | Dual Car Audio & Video
Location of reset on unit
when you disconnect it from cables, it resets. But i believe that is not the problem. Check speaker cables. I think you have problem with internal power amps. They have thermal and current protection. look for short circuits on speakers or speaker cables.
May 30, 2009 | Sony CDX-GT500 CD Player
Nothing turns on
hi whats the makes and models of the audio?
Dec 07, 2007 | Sony CDX-646 10-Disc CD Changer
Brand New Unit Will Not Accept ANY Type of CD
I am having the same problem but only with a KDC-MP335 unit. I installed it in a 1995 Jeep Grand Cherokee to the stock system, pretty easy install just matching colors for wires and everything works (Radio). but not one CD plays. it says reading and it acts as if it is playing the tracks but no sound... what is going on? did I mess up wiring it or something?
Oct 03, 2006 | Kenwood KDC-X890 CD Player
Dual XD-7500 CD Player Logo
243 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
