Question about Kenmore Oasis HE 27082 Top Load Washer
Lid locked my machine stopped and powered off i cannot get it to turn back on clothes are locked in power ok to outlet i disconnected hoses to drain but nothing is coming out machine gave me no signs of trouble only 8 months old
  • Anonymous Dec 28, 2008
    Same exact problem. Now that I'm searching online for a solution, I find all these people with the same problem. No Power, Lid Locked and clothes remain trapped. This sucks.
  • 240 Answers
Sounds like a falled board in the machine itself. At 8 months old, is your warranty still in effect? If so, may want to call the Searsman. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE:
How do i fix the Ld code on a whirlpool cabrio top load washer WTW6200SW2?
Troubleshooting Cabrio, Bravos, & Oasis Washer Problems Cabrio, Bravos, Oasis Washing Machine Overview
Washer Components
Diagnostic Mode & Tests ' Tips & Tricks Error Codes LF ' Ld ' uL ' oL ' Sd ' lid ' Po ' HC ' dL ' dU ' F1 ' F2 ' F30 ' F32 ' F40 ' F41 ' F50 ' F51 'F52 ' F53 ' F54 ' F70 ' F71 ' F72 ' F80 ' F81 ' F82 ' F83 ' F84 ' F85Always disconnect the washing machine's power supply before working on the appliance!Washing Machine Models That ApplyWhirlpool Cabrio Washing Machines
WTW6200SW0, WTW6200SW1, WTW6200SW2, WTW6200SW3, WTW6200VW0, WTW6200VW1, WTW6300SB0, WTW6300SB1, WTW6300SB2, WTW6300SG0, WTW6300SG1, WTW6300SG2, WTW6300SW0, WTW6300SW1, WTW6300SW2, WTW6300WW0, WTW6340WW0, WTW6400SW0, WTW6400SW1, WTW6400SW2, WTW6400SW3, WTW6500WW1, WTW6600SB0, WTW6600SB1, WTW6600SB2, WTW6600SB3, WTW6600SG0, WTW6600SG1, WTW6600SG2, WTW6600SG3, WTW6600SW0, WTW6600SW1, WTW6600SW2, WTW6600SW3, WTW6700TU1, WTW6700TU2, WTW6700TW0, WTW6700TW1, WTW6700TW2, WTW6800WB1, WTW6800WL1, WTW6800WW1 WTW7300XW0, WTW7340XW0, WTW7600XW0, WTW7800XW0
Maytag Bravos Washing Machines
MTW6300TQ0, MTW6300TQ1, MTW6400TQ0, MTW6500TQ0, MTW6600TB0, MTW6600TB1, MTW6600TQ0, MTW6600TQ1, MTW6700TQ0, MTW6700TQ1, MVWB300WQ0, MVWB300WQ1, MVWB400VQ0, MVWB450WQ0, MVWB450WQ1, MVWB700VQ0, MVWB750WB0, MVWB750WB1, MVWB750WL0, MVWB750WL1, MVWB750WQ0, MVWB750WQ1, MVWB750WR0, MVWB750WR1, MVWB800VB0, MVWB800VQ0, MVWB800VU0, MVWB850WB0, MVWB850WB1, MVWB850WL0, MVWB850WL1, MVWB850WQ0, MVWB850WQ1, MVWB850WR0, MVWB850WR1
Kenmore Oasis Washing Machines
110.27092603, 110.27092602, 110.27092601, 110.27092600, 110.27087605, 110.27087604, 110.27087603, 110.27087602, 110.27087601, 110.27087600, 110.27086605, 110.27086604, 110.27086603, 110.27086602, 110.27086601, 110.27082605, 110.27082604, 110.27082603, 110.27082602, 110.27082601, 110.27082600, 110.27072604, 110.27072603, 110.27072602, 110.27072601, 110.27072600, 110.27062604, 110.27062603, 110.27062602, 110.27062601, 110.27062600, 110.27052602, 110.27052600, 110.27042603, 110.27042602, 110.27042601, 110.27042600, 110.27032603, 110.27032602, 110.27032601, 110.27032600
NOTE: For All Error Codes
First press PAUSE/CANCEL once to clear the error code.
If code appears again put it through an automatic diagnostic cycle while you enjoy a nice soothing cup of tea. (Watch The Cabrio, Bravos, Oasis Diagnostics Video) This will reveal any stored error codes. Then you will be able to better use the repair guide to fix the major malfunction. Now put the tea down and get to work!
flood stop water supply hoses that may have closed internally?Is the drain hose sticking too far into your home's drain pipe (siphoning)?
Is the pressure transducer hose kinked, disconnected, or punctured?
Back to Top
Press PAUSE/CANCEL to clear display. pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests Washer Diagnostic Modes and Tests "Po" Pump Out (Lid Opened) Po flashes when the lid of the washing machine has been left open for more than 10 minutes. Close the lid to stop the drain pump.
"HC" Hot & Cold Hoses Switched This code will appear at the end of the wash cycle to indicate that the hot and cold-water inlet hoses are reversed.
"dL" Door/Lid Cannot Lock (Stored Error Codes F80, F82, F84, F85) Indicates the lid cannot lock.
Check for items caught in the lid keeping it from closing completely.
Is soap, fabric softener, or anything else keeping the lock from extending into the lid?
The control detects an open lid switch, or cannot determine if the lid is locked. Test the lid lock connection to the washer's control board and lid lock resistance levels.
Press PAUSE/CANCEL once to clear the code. "Ld" Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Tip
How to fix a washing machine that won't drain.
InstructionsThings You'll Need:
  • Screw driver/socket set
  • bucket
  • towls
  1. Step 1 Check and make sure that the washer is plugged in. I know that sounds stupid, but washers move and it has happened before.
  2. Step 2 Check and see if the washer works during the rinse cycle. if the motor moves then skip to step 3 If the motor does not turn then you need to test the power outlet. use a small hand held appliance like a hand mixer to make sure the outlet has power. If the outlet has no power you need to check your breakers. If the outlet has power you need to call a repairman for your washer.
  3. Step 3 Good news because your washer works on the rinse cycle your problem may not be that severe. First check to make sure your lid switch is working. The lid switch is a safety device that ensures that the lid is closed before the machine will begin the spin cycle. to check the lid switch simply close and open the lid several times. each time you close the lid you should here a distinctive click. if there is no click then you need to replace the lid switch. if the is a click continue to step 4
  4. Step 4 Ok you have power and you lid switch is working that means you have one of two things going on. 1. you have clog in the line or 2. your pump is burnt out. To check for a clog start at the back of the washer and remove the drain hose. Be ready for water! It may come pouring out. if water does come pouring out then you need to check the drain hose for a clog. If there is no clog in the drain hose then you have a bad pump and it will have to be replaced. If water does not come out when you remove the drain hose then you have a clog. the clog is either in the pump or in the upper hose that runs from the tank to pump.
Tips & Warnings
  • make sure to unplug the washer before disassembling. water and electricity don't play well together.
on Dec 02, 2009 | Washing Machines
MY HP 8500A HAS STARTED PRINTING WHOLE PAGE BARCODE LOOKING LINES WHEN I PRINT OR COPY IN BLACK. COLOR LOOKS GREAT. IVE CLEANED THE PRINT HEADS AND ALIGNED THEM. ANY OTHER OPTIONS? THANKS
Solution one: Reset the product If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product Press the Power button (c01602202.gif ) to turn on the product.Disconnect the power cord from the rear of the product.Unplug the power cord from the wall outlet.Wait 30 seconds.Plug the power cord back into the wall outlet. Reconnect the power cord to the rear of the product.Press the Power utton (c01602202.gif ) to turn on the product.Try to copy, fax, or scan again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution.
Solution two: Clean the scanner glass and scanner lid
If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the product.Before you begin, gather the following materials:Several clean, soft, lint-free cloths
Mild glass cleaner
CAUTION: Use only glass cleaner to clean the scanner glass. Do not use cleaners that contain abrasives, acetone, benzene, or carbon tetrachloride. These substances can damage the product. Avoid isopropyl alcohol (rubbing alcohol) because it can leave streaks on the glass.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Lift the scanner lid. Figure 3: Lift the scanner lid
  4. Spray a clean, soft, lint-free cloth with mild glass cleaner.
    CAUTION: To protect the scanner, do not spray the glass cleaner directly on the glass.
  5. Clean the scanner glass with the lint-free cloth. Figure 4: The scanner glass
  6. Clean the glass strip next to the scanner glass with the lint-free cloth. Figure 5: The glass strip
  7. Dry the scanner glass and the glass strip thoroughly with a clean, dry cloth or chamois to prevent spotting, and then dry the white underside of the scanner lid.
    NOTE: Do not use paper-based wipes or tissues that can leave fiber residue.
  8. Clean the white underside of the scanner lid. Figure 6: The underside of the scanner lid
  9. Close the scanner lid.
  10. Reconnect the power cord to the rear of the product.
  11. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
  12. Try to copy, fax, or scan again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution three: Clean the automatic document feeder (ADF) Use the following steps to clean the automatic document feeder. Step one: Clean the ADF rollers and separator pad
  1. Gather the following materials:
    • A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
    • Distilled, filtered, or bottled water (tap water might damage the product)
  2. Remove any documents from the document feeder tray.
  3. Press the Power button (c01602202.gif ) to turn off the product.
  4. Disconnect the power cord from the rear of the product.
  5. Lift the cover of the ADF until it stops. Figure 7: Lift the ADF cover
  6. Find the pick rollers and separator pad. Figure 8: Locations of the pick rollers and separator padLightly dampen a clean lint-free cloth with distilled or bottled water, and then squeeze any excess liquid from the cloth.
  7. Use the damp cloth to wipe any residue off the separator pad.
Aug 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Whirlpool washing machine will wash but will stop and not drain or rinse
Hi!!
In order for the high speed spinning (rinse) cycle to begin, the lid must be shut. If your unit is top load, the problem is more likely the lid switch. or the tab on the lid that activates the switch is broken. If the tab is OK, disconnect unit from power outlet, remove back panel and trace the two wires going to the switch, once located, use a piece of wire to jump the two together, reconnect unit to power outlet and set the knob to rinse cycle, if unit works, replace switch.
Good Luck!!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 16, 2011 | Whirlpool Washing Machines
Beko wm5120...no power even with new fuse
Instructions
  1. Close the lid or door. Washing machines automatically stop when the lid or door is open. Lift the clothing and move it slightly. If the washing machine is overloaded with towels or heavy garments, it might become unbalanced. The washer won't run until the items are adjusted.
  2. High-efficiency machines might stop running when regular detergent is used or too much high-efficiency laundry soap is poured in. If you suspect that the laundry soap is the problem, cancel the cycle and press the "Spin" or "Drain" cycles. Restart the cycle, but do not add more detergent.
  3. Inspect the water outlets. Turn faucets to the left to ensure that both the hot and cold water hoses are open. Tug on the hoses to make sure they are attached and inspect the hoses for thin spots that might be causing leaks. Make sure the hoses aren't kinked. Detach the hoses and run clean water through them to remove clogs.
  4. Is the washer's cord plugged into a grounded outlet? Never use extension cords to power washing machines. Check the circuit box for blown fuses.
Feb 02, 2011 | Washing Machines
Error on control panel "oL"
Hi
Error OL means that the washer has sensed an overload (OL) condition. It can also be a false error code appearing due to faulty lid switch. Sometimes this error code appears when lid is not closed/opened properly. You can check the lid switch for any disconnections, if the connection to lid switch is fine then use a multimeter to check the continuity of the lid switch. If the lid switch is fine then there is a piece of clothing stuck between inner basket and the outer tub. Disconnect the washer from the power outlet and then try moving the drum with your hand and check if it turns freely or is offering any resistance. If it is not moving freely then it is due to rusted drive shaft or motor. Hope this helps... Please post back if you need more assistance.
Daniel
Dec 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Wont drain
1. Check and make sure that the washer is plugged in. I know that sounds stupid, but washers move and it has happened before.
2. Check and see if the washer works during the rinse cycle. if the motor moves then skip to step 3 If the motor does not turn then you need to test the power outlet. use a small hand held appliance like a hand mixer to make sure the outlet has power. If the outlet has no power you need to check your breakers. If the outlet has power you need to call a repairman for your washer.
3.Good news because your washer works on the rinse cycle your problem may not be that severe. First check to make sure your lid switch is working. The lid switch is a safety device that ensures that the lid is closed before the machine will begin the spin cycle. to check the lid switch simply close and open the lid several times. each time you close the lid you should here a distinctive click. if there is no click then you need to replace the lid switch. if the is a click continue to step 4
4. Ok you have power and you lid switch is working that means you have one of two things going on. 1. you have clog in the line or 2. your pump is burnt out. To check for a clog start at the back of the washer and remove the drain hose. Be ready for water! It may come pouring out. if water does come pouring out then you need to check the drain hose for a clog. If there is no clog in the drain hose then you have a bad pump and it will have to be replaced. If water does not come out when you remove the drain hose then you have a clog. the clog is either in the pump or in the upper hose that runs from the tank to pump.
Nov 20, 2010 | Maytag Washing Machines
Hotpoint , no power, full of water
Turn off the water supply to the machine
Take the drain hose off the back of the machine and drop it into a bucket , you will need to do this several times.(Take off any clips that stop it from being laid flat on the floor)
Once all of the water is out of the machine try powering it up again, if it lights up do a spin to get the clothes dry , leaving the outlet hose in the bucket.
If that works then once the machine is dry try turning on the water supply with the machine turned off , if water runs into the machine then you have a faulty fill valve.
If that is ok then check the pressure switch and Air Bell which sits on the back of the main drum you could have a soap ball in the Air Bell which will false out the machine and cause overfilling
If there is no power check the mains supply to the wall outlet then the plug top wiring and any fuse fitted inside the plug top
After that it is down to a man with a test meter
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis - Lid Locked Shut and No Power
take your outlet pipe and place into a bucket so that it is low to the ground if water comes out then it could be that your pump is faulty when the water has all drained away the pressure switch will reset itself and the lid will now open if no water comes out un-clamp your outlet pipe from your pump if then water comes out then your pipe will be blocked m8
Aug 14, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
116 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
