Question about Samsung SGH-d807 Cellular Phone
Ribbon Cable LCD
Ok. When I yanked off the ribbon on the LCD, I got some gold things attached to the green tape like this: http://i4.tinypic.com/63ctpuf.jpg I just wanted to ask if it was normal for those things to get pulled off. Here's the picture of the LCD and Circuit board after i took off the cable. http://i11.tinypic.com/62j29g2.jpg http://i19.tinypic.com/6h6aeld.jpg Altogether, I just wanted to ask if I'm still able to buy a ribbon cable and replace it. I don't know where the gold things came from. Hopefully, it didn't come from the phone. But if anyone had this problem, please notify me. Because I don't know if a new ribbon cable would still work. Thank you. P.S: Do you know where to buy a new Ribbon cable?
    Brigadier General:
  • 7,752 Answers
Yes you can still do that but i think it would be best for you to take the phone to a professional mobile service center and have them replace it for you.
Posted on Jan 29, 2008
2 Suggested Answers
SOURCE:
Bajanguru
  • 7752 Answers
SOURCE: Is this what it's supposed to look like when i ripped the Ribbon off the LCD and circuit board?
take the phone to a mobile service center and have them repair it for you.
Resoldered the UPS port. Now cannot reattach the ribbon cable. Any suggestions?
Resoldering is OK, but reinforcing the connector with a bonding material to prevent the connector from moving is also required.
As for the LCD ribbon cable, there is a horizontal lock down latch, about an inch long. that locked the ribbon to the board. If that latch is cracked, broken or missing, it is game over for the GPS. Yes, the latches can be replaced but it is very tedious.
If the latch is ok, all you need to do is flip the latch up. Slide the ribbon cable into the mating connector, with the gold contacts face down. Slide the ribbon in as far as it will go and using two fingers spaced at either end of the latch, flip the latch down, locking it into place. It will grab the ribbon and make the connection to the board.
Jun 20, 2015 | Garmin Nuvi 1490LMT Nuvi 1490 w/ Lifetime...
Screen kodak on an az521 has gone green
take it apart, clean the gold parts of the lcd ribbon cable with a pencil eraser then re-seat the cable back in the connector.
May 24, 2014 | Cameras
Where can i get ribbon connectors for sony stero system part#26AWG THE END OF THE CONNECTED IS BROKEN OFF
I doubt at this point you will ever find a new one but hope is not lost entirely. Since these are not high current cables the possibility exists to solder the one end of a ribbon cable to the board and then attach a dB connector to the cable for interconnection and taking the system apart. This would solve this problem. In fact ribbon cable of different types can be obtained new and this might be a good upgrade to do as most dB connectors are made with Gold flashed pins. The trouble is not many technicians will want to do this for cheap.
Oct 24, 2012 | Audio Players & Recorders
When i turn it on the screen is white and dose not show any thing
Can you take pictures with it? Try to take pictures and then try to download to PC. If it is ok, then the LCD screen may be bad or the Ribbon cable may be misaligned from its connector. Open the camera (a few screws). Lift the pressure plate in the LCD ribbon cable connector gently, and pull out the ribbon cable. Reinsert it and close the pressure plate. If that doesnt help, I suspect the LCD. You may need to replace the LCD.
Jan 03, 2011 | Olympus FE-170 Digital Camera
REPLACEING SCREEN ON G800
To replace the screen of the samsung g800, get there appropriate screwdriver and follow the process below;
  1. Remove your back cover, battery, sim and memory card. Remove the six screws (two at the bottom are covered by rubber stoppers which are easily removed). You can now remove the battery compartment.
  2. Below you can see the battery cover removed. You now need to disconnect the circled ribbon connector. It attaches like a plug and socket. Simply lift the connector up to unplug it.
  3. Lift the circuit board up to reveal another connector. It attaches like the last one. Unplug this
  4. You can now remove the circuit board. Note that the ribbon running along the right of the circuit board, with the volume buttons at the end, is lightly stuck down with a tacky glue or double sided tape.
  5. Remove the grey part. Note that the ribbon with the camera button at the end is stuck down lightly. Next remove the four screws.
  6. Part of the slider can now be removed.
  7. Next remove the two rubber stoppers at the top of the phone to reveal two more screws. Remove the four screws.
  8. Remove the ribbon which is stuck to the black rectangle. It'll just peel back.
  9. Run your plastic tool all the way around the join of the front cover to unclip it.
  10. Lift the screen away from the phone at the point on the opposite side. The screen is stuck down lightly with double sided tape.
  11. You should now have the LCD removed.
  12. Turn the LCD screen over and remove all the green tape you see. You now need to detach a number or ribbons. The ribbon attaches like a plug and socket. All the other ribbons have a hinge which you need to flick up to release.
  13. Reverse the whole procedure for reassembly.
Take care
Jul 04, 2010 | Samsung SGH-G800 Cellular Phone
How do you make my screen work? All the buttons work just not the screen buttons
The reason your screen wont work is because there is a problem with the flexi ribbon that connects the screen to the panel of the phone.
To fix the screen, you would have to dismantle the phone and replace the flexi ribbon.
To disassemble your phone, you have to follow the process below;
  1. Get the appropriate screwdriver(Phillips screwdriver, plastic tool such as a guitar plectrum or credit card.),
  2. Remove your battery cover, your battery, your sim and your memory card,
  3. Remove the four screws you can see.
  4. Peel back the sticker. You may need something with a thin, sharp point to peel the sticker back (samsungmobile.com). Two rubber stoppers need to be levered out to reveal two more screws that must be removed.
  5. Run your plastic tool along the join of the battery compartment to separate the phone into two halves. Next you need to disconnect the ribbon. This attaches like a plug and socket. Simply lift the connector up, away from the circuit board to unplug it. Remove the screw by the left. You can now lift the green circuit board away from the phone. A little force is required.
  6. You should now have the circuit board removed. Note that a ribbon, will have disconnected when you removed the circuit board. Again, this attaches like a plug and socket.
  7. Remove the identification sticker. Remove the volume button which will be loose. The buttons underneath will be lightly stuck to the side of the phone and need to be peeled away. Lever off the grey part.
  8. Remove the four screws you have access to (one is under the ribbon cable).
  9. You should now be able to separate the phone into two parts. Two rubber stoppers need to be levered out to reveal two screws. Remove these plus the two others screws you see.
  10. Run your credit card around the join of the housing to release it. Once you have the two parts separated as far as shown below, pull in the upward direction (towards the camera).
  11. Pull the little metal bars in the direction of the camera.
  12. Lever out the camera, speaker and ringer. They'll be stuck down with double sided tape. Lever out the the screen. Slide your plastic tool under the green circuit board to release the LCD screen.
  13. You should now have the LCD screen removed,
  14. Turn the screen over. Remove the green tape at the top. Now release the circled ribbons. To do so, flick the black latches up and then pull each ribbon away.
  15. That is the ribbon that needs replacement.
  16. Reverse the process to reassemble the phone back together.
Take care
Jun 24, 2010 | Samsung SGH-Z720 Cellular Phone
PS2 Power Ribbon
you need to replaced the ribbon cable
go to www.repairmyvideogame.com
they have the parts for $1.00
Oct 17, 2007 | Sony PlayStation 2 (PS2) Console
D500
faulty flat cable that connects lower and upper part of the phone...
Aug 26, 2007 | Samsung SGH-D500 Cellular Phone
Samsung sgh-d807
I just finished disassembly and it wasn't that bad. Take off all four screws around the battery, then carefully but forcefully take the plastic casing off. Then, take the 2 screws on the main circuit board. That will reveal one connection for the ribbon cable, take that off. Under that is the backplate sliding mechanism of the phone. There will be 6 screws on this assembly, one of them under cable the connects to the keyboarb (bottom right). You will have to take off a green tape and also a gold padding to get to this final screw. After that is off, you will see the other half of the ribbon. Take that one off also, just yank it off. Install the new ribbon tape, make sure you don't rip it, and you're set. good luck. EE
Aug 09, 2007 | Samsung SGH-d807 Cellular Phone
Samsung SGH-d807 Cellular Phone Logo
97 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
