Question about Samsung V20 XVC 2400 Notebook
Samsung v20 disassembly
Hi My Samsung V20 has a problem with the power supply socket, and I want to replace the module of which the socket is part. However I am stuck trying to open the case. I have removed 12 screws (8 main screws, plus HDD, Keyboard, DVD and also a casing screw concealed by the DVD) from underneath, and have also removed the components they held. However the case appears to be held by two plastic latches on either side: between the LEDs on the right hand side, and at the corresponding point on the left. Can you tell me how I release the latches (if this is what they are) and get the casing open? Regards, PaddyB
  • freddie43 Jan 30, 2008
    Hi. I have the same problem - need to replace the DC power socket. Have removed all screws and keyboard (+ extra scerws), but cannot take the cover apart. Am I missing something? And should I be attacking this from the top or the bottom?
    OK. I lifted the whole top off, but what do you do with the ribbin connectors for the keyboard and pad - do they just slide horizontally out of the holders?
After removing the screws, lift the keypad by releasing the two latches just below the ALT key and WINDOWS key. Two more screws are hidden beneath the keyboard. Hope this helps
Posted on Sep 05, 2007
  • creativeptan Apr 03, 2011
    thanks it worked
  • 883 Answers
Yes, they are, in effect, latches. You must determine which case half contains the "male" tab and then compress near that tab to release it from the tab's latch (female). The latch may look like an enclosed "hook" or depression or relief that the tab falls into perfectly when latched. The tab is usually ramp-shaped or wedge-shaped to allow easy alignment before the user pushes the tab in allowing the ramp to slightly bend the tab inward and then allowing the tab to snap back outward into the latch area after end of ramp. It really is a "spring" effect on a very small scale. Usually, the tabs are located on the top half of the case.
Posted on Sep 04, 2007
SOURCE:
Samsung sens v20 laptop power on but no display
Any sound? Does the HDD led blink during start-up? Can you hook it up to a external display? If so, what is on the screen?
Nov 27, 2013 | Samsung V20 XVC 2400 Notebook
Trying to get instructions of to how to use a laptop samsung v20 computer laptop without the battery and use main power only, Computer came without any instructions or manual.
Hi
just plug in the electric cord from computer to plug switch on and away you go
just the same as if you were on battery power
only the electric wont run out on you
here is a link to get your user manual but it may be in your programs or documents
http://www.cintelcorp.net/samsung-v20-xvc-2400-manual
Aug 21, 2011 | Samsung V20 XVC 2400 Notebook
How do i enable wireless function on samsung v20 laptop?
you can try pressing fn+f10 to switch on and switch off wireless
Aug 11, 2009 | Samsung V20 XVC 2400 Notebook
Reformat my samsung v20 back to factory conditions
You pc has a hidden recovery partition. You need to press F11 at boot up to launch recovery. But before you do make sure to back up all your data. the recovery wizzard will walk you though the whole process.
Good Luck
May 04, 2009 | Samsung V20 XVC 2400 Notebook
Samsung v20 display keeps going i have changed the screen cable
sounds like your new screen cable is either loose or faulty.i had same problem and was only after i had removed keyboard and ensured cable was tightly connected did i solve the problem.it seems to be a design fault in the samsung v20
Jan 24, 2009 | Samsung V20 XVC 2400 Notebook
Installing built in mic
On your task bar look for a speaker symbol
right-click
click on adjust sound properties or something similar
there you can configure the microphone
Dec 07, 2008 | Samsung V20 XTC 1800 Notebook
Hi, i have a samsung v20 laptop.2 questions...
I have a Samsung V20 for many years and I know it doesn't support a wireless connection built in. But if you connect a USB like myself you can have access to the internet wirelessly. The flikering on the screen are you sure you haven't got a screen saver switched on, you may have it set to a clear black screen and like you say have to tap the keyboard and it comes back to life. It may also have hibernation switched on which will automatically turn off the screen have so many minutes you can change all these setting by right clicking on the desktop and selecting properties and under the screen saver tab there will be a power btton you should see hibernation and other tabs across the top these can be altered to whatever you want.
Hope this of use.
Dec 05, 2008 | Samsung V20 XVC 2400 Notebook
Screen fault on samsung v20
screen tube or inverter board faulty.
change the inverter board, then replace the CFL tube.
Or replace the whole tft screen.
Mike @ Compurepair.
Jul 09, 2008 | Samsung V20 XVC 2400 Notebook
Samsung cd/dvd drive
you may be having problem with your cd/dvd drive
May 02, 2008 | Samsung V20 XVC 2400 Notebook
Samsung V20 XVC 2400 Notebook Logo
738 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
