Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582
Problem for Generac Guardian Ultra Source 15,000 Watt Portable...
I have a Generac 15000 watt portable generator. It
By madmarsh6 on Apr 05, 2009
I have a Generac 15000 watt portable generator. It cranks great, but will not start. The plugs are wet, doesn't seem to be getting any spark. Have replaced plugs, any suggestion.
Same Problem
Apr 27, 2009
-   im haveing the same trouble with our genorac 15k, plugs are wet, i remove plugs clear the cylinders of all fuel and reinstall plugs and then she starts. but when the idle controol kicks in the Genorator fluds out. When i shut idle controol off the unit continues to run but extreemly rich in fuel,i think it is the carbarator something keeping the fuel flowing thuss fludding out the unit. i have not removed the carb yet but this is what im going to do next. any ideas?-   rzagami
Solution #1
posted on Apr 27, 2009
Not Rated)
rzagami
Rank: Apprentice
Rating: 0%, 0 votes
I have solved the flooding problem . unfortanetly you must remove the carb to fix it. once you remove the carb you need to remove the fuel bowl. In the bottem of the fuel bowl there is a electronic seloniod that controols the amount of fule going to combustion. this aria had varnish and gunk built up around the plunger of the selonoid, long story short clean this out with carb and chook cleaner and put it back together. start her up and she will run like a champ.
Was this helpful?
Yes
No
Solution #2
posted on Apr 11, 2009
Not Rated)
chev49
Rank: Guru
Rating: 91%, 121 votes
If you have fuel to the plugs, have you checked to see if you have good spark? I normally use a vice grip and clamp a new plug to the engine (with the ignition wire attatched to it) somewhere to ground it and crank the engine to see if I have ignition. Helps to have 02 people - one to watch the plug, one to crank engine...Also, if you have an old plug and flooded it, it probably wont start anyway.
Was this helpful?
Yes
No
Popular Solutions for Generac Guardian Ultra Source
Questions and Unsolved Problems for Generac Guardian Ultra Source
Do you recommend Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582?
Answer
Answer
how do you get into the parameters to change resolution
Answer
I need parts for an Berger Model AK-46 Transit. Specifically the Trianglular mirror that is mounted... (More)
Answer
have an old sears brand thermostat that I am replacing...two wires on back not marked one held in w/... (More)
Answer
looking for a manual for strait-line laser tape
Answer
item # 0045821 serial # 4315753t it is a generac portable gen it runs great it. the engine is not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Generac Guardian Ultra Source...:
Top Measurement Tool Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Measurement Tool Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
