Question about RCA D61W136D 61 in. TV/DVD Combo
RCA tv Making a clicking noise
The tv makes a clicking noise like you are turning on the tv again and again. and sometimes the screen flickers. I need to know if this is a serious problem and if it is worth fixing. Thanks
  • weesa Oct 04, 2007
    thank you so much for your answer on this I thought that it might be the same thing and the tv repair guy wont even look at the tv unless we take it there but that means 1 hour of driving in the back of a truck.
    Thanks again!!!!!!
    Genius:
  • 1,139 Answers
This is a power supply problem it may be as simple as a blown fuse or as complex as a malfunctioning IHVT (Integrated High Voltage Transformer). Is it worth fixing, only you can answer that I would estimate the cost from $100.00 - $500.00 at least.
Posted on Oct 03, 2007
T.v. making a clicking noise, how can I correct it.
Posted on Sep 26, 2009
SOURCE:
Sony 52xbr4 screen flickering
Fault with the main power supply regulator board. Ubnormal DC voltage output from it. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 29, 2014 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Westinghouse LVM 37w1 Screen goes black, blue light stays on, sometimes turning the tv power off and on fixes it, sometimes just have to wait about 10 minutes and it works again. Could it be the...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 01, 2011 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
I need a power supply board for my 42 inch rca lcd,where do i buy??
Apr 27, 2011 | RCA L42FHD38 42 in. HDTV LCD TV
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
Flickering Picture?
Your set might have a high voltage leak and that is the noise you hear when is showing the screen problem or even maybe an arking too ,either one is related to the high voltage and it can be dangerous,if you are familiar with tv service you can try to see where is arking and replace the part with an exact replacement but if the set has a leak you will not see it and is not safe to be close to it,if you are not too familiar be safe and call for assistance from a servicer.
Oct 27, 2006 | RCA F35731MB 35" TV
RCA D61W136D 61 in. TV/DVD Combo Logo
2,631 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
